Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Translations
- This topic has 3 replies, 2 voices, and was last updated 5 years, 5 months ago by
Sarmistha Chakraborty.
- March 16, 2020 at 6:26 am #111741
morakisvang
ParticipantI have translate 100% to Greek the
1) wc-frontend manager-ultimate
2) wc-frontend-manager
3) wc-multivendor-membership
4) wc-multivendor-marketplace
5) wc-frontend-manager-groups-staffs
in (filename)-el and (filename)-el_GR (the same). I put it in plugins Lang folder in server. I dont use any loco or other plugin. It works.But when the plugins updated the tranlslations is deleted and I must upload them again in server manualy.
What i have to do?Thanks.
- March 16, 2020 at 1:31 pm #111807
Yes If you update the plugins your created file will be removed. That’s why we suggest use Loco translate for translating text Or back-up your translated files and put them after update your plugins.
- March 16, 2020 at 2:16 pm #111809
morakisvang
ParticipantThanks for your reply
I think that Loco haves the same problem deleting *-el.po and *-el.mo files on updates.There is the problem of a lot of plugins.
thanks
- March 16, 2020 at 3:58 pm #111820
Yes, That’s why choose the file location in Loco-Translate folder.(PFA)
https://localise.biz/wordpress/plugin/beginnersThanks.
