Durga Puja
01Day 20Hr 39Min 40Sec
Durga Puja
Two-way Gcal sync for vendors added in 6.3.1 – how does it work?
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Appointment › Two-way Gcal sync for vendors added in 6.3.1 – how does it work?
Viewing 2 reply threads
    • #92604
      me
      In the changelog there is this entry for 6.3.1 of WCFM Ultimate:
      • Enhance – WC Appointments “two way” Gcal sync compatibility added for vendors
      What changed compared to previous versions? Is there a documentation for this feature?
      Previously I had to add Staff user role to vendors manually, and add them to their own products as staff. That was the only way for sync to work both ways. Is that no longer needed? I can’t seem to get sync to work anymore, even with the this trick.
      Can you help me understand what changed in 6.3.1 regarding two-way-sync, and how do I use this feature?
    • #93527
      – Keep that as this trick is for check product availability.
      2-way sync is for Google calendar.
      • #93703
        me
        I know 2-way sync is for google calendar, obviously.
        I still don’t understand what changed in 6.3.1 regarding two-way-sync, and how do I use this feature?
        Also, can you maybe help me with a code snippet for automatically assigning vendor as staff for their appointment products?
        I have to do it manually because I don’t know how to automate it.
    • #94041
      – Site events and calendar events both will visible in Calendar.
      – Well, for this first we have to make those vendors staff as well. Please contact us here for the purpose- https://wclovers.com/woocommerce-multivendor-customization/
  • The topic ‘Two-way Gcal sync for vendors added in 6.3.1 – how does it work?’ is closed to new replies.
