Diwali
02Day 02Hr 56Min 22Sec
Diwali
Unable to manage products
Viewing 7 reply threads
    • #25385
      Alice
      Hey,
      I recently updated to the newest version of the plugin and now none of the vendors, including me (admin) are able to view the products on the front end, the table is just empty.
      Any idea why this would be happening?
    • #25386
      Alice
    • #25390
      Alice
    • #25391
      Alice
      I’ve found it seems to be a conflict with Autoptimise plugin when using the JavaScript Options – If the Optimize JavaScript Code is active then the products don’t show.
      Is there a fix for this or is it best if I keep Optimize JavaScript unactive?
    • #25392
      Let me check this once!
      Thanks fro all the details.
    • #25393
      I have just checked – now Autoptimized is enabled and Products are visible as well.
      Now, when you are getting any issues? For any particular setting in Autoptimize?
    • #25500
      Alice Coleman
      I’ve unchecked the setting for now so my vendors can still see their products, but it’s the Optimize JavaScript Code setting that seems to cause the error.
    • #25505
      Yeah, possible. AUtoptimize advance JS setting may cause some issues as there has lots of inter-dependencies.
  • The topic ‘Unable to manage products’ is closed to new replies.
