Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Understanding "Commission"
- This topic has 6 replies, 5 voices, and was last updated 5 years, 3 months ago by
sohaiilbahrii.
- April 22, 2020 at 2:37 pm #121713
Betro Hakala
ParticipantCan someone clarify me why there’s two options (admin and vendor) for commissions?
If I understand the logic correctly, me, as a site owner, I should set the commission to “admin” and if I want to get i.e. 15% commission from all the vendors that are selling their products, I should set the settings to: “Commission For admin”, “Commission mode percent” and the “Commission Percent 15%”. And if I’m right, then what does the Vendor commission stand for?
Did I understand everything correctly? The default commission value was 80%, so this is why I’m clarifying this. The manuals did not have any examples how the commission are calculated and I would suggest you add these so people would ask stupid questions like I am doing.
“What is commission in simple terms?
A commission is a fee paid to an agent as compensation for executing a transaction. It is calculated either as a percentage of the transaction value or as a flat fee.” Therefore, 80% default commission would indicate, that the vendor should pay 80% fee. - April 22, 2020 at 5:46 pm #121802
Avinaba
MemberHi
– You are correct in getting this, basically we have given feasibility to set the percentage in both ways, thus you can set commission with respect to admins, as well as for vendors, only one has to make sure that the values are adjusted accordingly.
For for selling USD 100, if admin wants 15% commission, he will set, commission for : Admin and percentage as 15.
Hope this helped.
- April 23, 2020 at 1:17 am #121973
Betro Hakala
ParticipantYes, this solves it. Thank you!
- April 25, 2020 at 4:21 pm #122906
tideon
ParticipantDear Support,
I was confused in the exact same way. In the real world a vendor never gets a commission, he gets a settlement. In English terms, the vendor cannot get a commission, because he is using the services of the platform. I also read your manual and was confused. The explanation you added above should be added to the documentation / manual.
- April 25, 2020 at 4:27 pm #122907
Avinaba
MemberOfcourse, we will take care of the same and add this for additional clarification
- June 29, 2020 at 8:55 am #144933
nextphasewebdesign
ParticipantHow would I set up a commission tier below. Any help would be great!
COMMISSION Tier 1 – <$500 = 15% Commission
COMMISSION Tier 2 – $500 – $999 = 10% Commission
COMMISSION Tier 3 – >$1000 = 5% Commission - July 31, 2020 at 6:25 pm #159147
sohaiilbahrii
ParticipantI need help to understand how can I setup the following commissions in multi vendor store in India
1) product category wise commission (one vendor can have multiple products and hence multiple product categories commission has to be setup)
2) fixed closing fee on the basis of order value. For eg – order 1 between 0-500 will be charged fixed Rs. 10 and Order between 5001-1000 will be charged fixed Rs. 20
PLSE HELP AS I AM NOT ABLE TO ABLE FINALISE THE WCFM because of this. Urgent
