00Day 11Hr 42Min 28Sec
urgent hep – My Icons turn into squares
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › urgent hep – My Icons turn into squares
Viewing 10 reply threads
    • #117585
      andre
      My site was working fine until recently, I have not added any new plugins, but now when I go to the vendors dashboard I can see the icons, when I click on memberships all the icons turn into little squares. I am now not able to update any settings, the site just hangs indefinitely and I have to close the browser and reload, However going back to membership the same happens again. I have tried 5 other templates including storefront, same result. I have also cleared the cash several times, same result We are nearly ready to launch and this is a major stumbling block please help
      I am using the following:
      WCFM – WooCommerce Multivendor Marketplace Version 3.3.7
      WCFM – WooCommerce Multivendor Marketplace – Elementor Version 1.1.1
      WCFM – WooCommerce Multivendor Membership Version 2.8.5
    • #117649
      andre
      Urgent Hi, please can someone help with the Icons turning into blocks, we are registered to supply the elderly with food and sanitizer products and our lockdown was extended by the president last night but my site is not working properly
    • #117691
      Please check your browser console whether there is any javascript error or not. Also go to wp-admin->WooCommerce->Status->Logs and check whether there is a fatal error or not.
      If you are not using all updated versions of our plugins then please do update them all and check again. Don’t forget to take backup of your database and all files before updating anything.
      Do let us know if you find something.
    • #117710
      andre
      Hi
      This is all that i found in the woocommerce logs
      wcfm-2020-04-04-afd9b3dd7e1fd31bc40a183aee99091b.log
      2020-04-04T21:08:22+00:00 DEBUG Mail Check Status:: 1
      I don’t see anything under chrome console
    • #117715
      andre
      WCFM – WooCommerce Frontend Manager Version 6.4.7
    • #117718
      Please share us your website login credentials and do share it as private reply here. We need to check.
    • #117720
      andre
    • #117744
      andre
    • #117767
      It’s working now.
      The “WordPress Address (URL)” and “Site Address (URL)” under wp-admin->Settings->General needed to set with “https” only.
    • #117807
      andre
      That is awesome, thank you so much, I really appreciate the support.
    • #136481
      You’re most welcome. 🙂
  • The topic ‘urgent hep – My Icons turn into squares’ is closed to new replies.
