Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Groups & Staffs › Urgent: Options missing for Store Vendor Capability.
- This topic has 5 replies, 2 voices, and was last updated 6 years, 2 months ago by
Sarmistha Chakraborty.
- April 23, 2020 at 6:03 pm #122206
Sarah
ParticipantMy store vendors have complained that features they had previously are no longer available. I can see in my capabilities section for store vendors that they are missing PDF Invoice and PDF Packing Slip options – whereas the store managers capability has these options available. How can we get these back to choose from for Sytore Vendors? There seem to be a number of options missing from store vendors capabilities….. Please can you address urgently.
View of Store Vendors Capabilities: https://imgur.com/PAWXFrV
View of Store Managers Capabilities: https://imgur.com/3m0SJeM
Thank you.
You must be logged in to view attached files. - April 24, 2020 at 12:35 pm #122429
Have you disable/turn-off the “Store Invoice” module from WCFM dashboard->Setiings->Modules (PFA)
Then Turn-on the option.Thanks.
You must be logged in to view attached files. - April 24, 2020 at 12:44 pm #122431
Sarah
ParticipantHi, I just tried that and no change.
- April 24, 2020 at 12:57 pm #122437
Did you add any custom code in your site?
Please check once only activate WooCommerce, WooCommerce PDF Invoices & Packing Slip and our WCFM plugins(WCFM-Ultimate plugin is required as you know).
Then let us know still you having same issue or not.Thanks.
- April 24, 2020 at 1:05 pm #122445
Sarah
ParticipantOk I did not have the Woo Commerce PDF Invoices & Packing Slip Plugin installed – did the system have another way to print invoices previously as vendors have said they were previously able to then the pdf option on their orders disappeared?
It is now showing up as an options since I installed the plugin. Thank you.
- April 24, 2020 at 1:08 pm #122447
For store invoice, Essential plugin for this module – WooCommerce PDF Invoice and Packing Slips
Please see our documentaton : https://wclovers.com/knowledgebase/wcfm-store-invoice/Thanks.
- The topic ‘Urgent: Options missing for Store Vendor Capability.’ is closed to new replies.
