Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM Marketplace – REST API › **URGENT/SITE CRASHING** Need help with AJAX calls/FrontEndManager
- This topic has 14 replies, 5 voices, and was last updated 5 years, 9 months ago by
ciccupio97.
- April 17, 2020 at 1:37 am #119882
mxlocker.com
ParticipantHello, currently we are using multivendor marketplace, WC frontend manager and it is causing a huge amount of AJAX calls causing the site to crash, eat up CPU, etc.
Please look at the video below, any help would be appreciated!
https://wpengine-ss.s3.amazonaws.com/2020-04-16_10-33-08.mp4
You must be logged in to view attached files. - April 17, 2020 at 1:20 pm #119963
gazArchitect
Participantup vote
I am interested in this answer as I have seen runaway admin-ajax.php on our server requiring it to be bounced. Unfortunately, in production there is no time to keep debugging so we are limited only to the event logs related to the crash.
- April 17, 2020 at 8:57 pm #120107
Thanks for getting in touch and sorry for any inconvenience caused.
By default the plugin checks for any new notifications every 1 min. Now, to solve the issue, either we can increase the time interval or disable auto update of notification feature. Let me know which option suits you and I’ll guide you accordingly.
Also, as I can see there are 2 more topics you have created regarding the same issue. I’m closing those, as we will continue the discussion here.
Thanks! - April 18, 2020 at 1:01 pm #120268
KeymasterHello,
Please update to our latest version, v3.3.8, there it is disabled by default.
Thanks! - April 19, 2020 at 1:07 pm #120561
gazArchitect
ParticipantI would like to see both paths to modifying admin-ajax if you could show. I can see use case for both solutions. Thank you.
/side question: I am not able to create a new issue here in boards. Is creating new part of premium?/
- April 21, 2020 at 1:31 pm #121280
KeymasterHello,
You can use the following filters to enable or disable this feature (v3.3.8 or above)-add_filter( 'wcfm_is_allow_desktop_notification', '__return_false' ); add_filter( 'wcfm_is_allow_new_message_check', '__return_false' );To change the default time interval between requests, use the following filter-
apply_filters( 'wcfm_new_message_check_duration', 60000 )You mentioned “I am not able to create a new issue here in boards.”, does this mean you can’t create new forum topics? Our forum is open for both our free and premium users. Please try using another browser or browser incognito mode.
Thanks! - April 22, 2020 at 10:57 am #121641
gazArchitect
ParticipantExcellent. Thank you for the reply. I will implement these.
Thank you also for reply to issue posting. Yes, I was not able to create a new topic under REST API forum. I was able to reply to existing topic feeds just not create new. I tried with Chrome per your advice and that worked. FYI Firefox 75.0 (64-bit) was the browser that failed on create new topic.
- April 22, 2020 at 1:31 pm #121678
KeymasterYou are always welcome 🙂
- April 23, 2020 at 1:37 pm #122114
gazArchitect
ParticipantI left 5 stars ;o) Will follow on twitter too. TY
- April 23, 2020 at 2:57 pm #122148
KeymasterThank You 🙂
- May 12, 2020 at 4:58 pm #130018
Oksana Grishchenko
ParticipantHello
How can disable checks for any new notifications every 1 min for vendors but at the same time it works for admin?
- May 12, 2020 at 5:28 pm #130025
You can use the following code to do that-function allow_only_for_admin( $status ) { if ( current_user_can( 'administrator' ) ) return true; return false; } add_filter( 'wcfm_is_allow_desktop_notification', 'allow_only_for_admin' ); add_filter( 'wcfm_is_allow_new_message_check', 'allow_only_for_admin' );Add this code to your child theme’s functions.php
In case you do not have a child theme then add code using this plugin – https://wordpress.org/plugins/code-snippets/
Let me know how this goes.
Thanks! - May 24, 2020 at 10:16 pm #134814
ciccupio97
ParticipantHow can i allow system to check for new notification to all vendors every 10 minutes?
- May 24, 2020 at 10:47 pm #134818
Kindly use the following filter for that purpose-add_filter( 'wcfm_is_allow_desktop_notification', '__return_true' ); add_filter( 'wcfm_is_allow_new_message_check', '__return_true' ); apply_filters( 'wcfm_new_message_check_duration', 600000 );Add this code to your child theme’s functions.php
Thanks! - May 25, 2020 at 2:54 am #134867
ciccupio97
Participantthank’s work fine
