Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › VARIANTS | ADMIN-MADE & VENDOR-MADE ATTRIBUTES
- This topic has 1 reply, 1 voice, and was last updated 6 years, 6 months ago by
Jasmin Kronewetter.
- April 20, 2020 at 12:04 pm #120857
Jasmin Kronewetter
ParticipantHi all, hoping someone can guide me in the right direction with a problem I’m having.
I’m building a multi-vendor marketplace with WCfM plugin & Martfury theme.
I want to give customers the ability to use extensive filtering options on the shop page, e.g. Shop by location, item type, or occasion.
So far, I’ve accomplished this through product-attributes.
I have admin-made attributes that the vendors can choose from when uploading a product, that will display as a filtering option (through a widget) in the shop page.
For example, a vendor uploads a product and selects ‘Item type’ – ‘Sustainable’ attribute, then their product will show up on the shop page when a customer chooses to filter by sustainable items.
Now, the problem I’m having is when a vendor uploads a variable product and needs to create attributes to add variations.
Once they do that AND also select their admin-made attributes for filtering options, ALL ATTRIBUTES SHOW UP AS VARIANTS ON THE PRODUCT PAGE 🙁 (see image attached) -> only the vendor-made attribute should show up as a variant, the admin-made attributes should just remain attributes for the purpose of filtering, not as a variant.
Can someone please guide me in the right direction for how I can best address this issue?
I’m contemplating on custom development to completely separate admin-made and vendor-made attributes, but I’m also wondering if there’s a simpler option to accomplish my goal that I’m not aware of?
You must be logged in to view attached files. - April 20, 2020 at 1:17 pm #120898
Jasmin Kronewetter
ParticipantProblem solved. I had some displaying issues through the theme and didn’t see the tickboxes.
- The topic ‘VARIANTS | ADMIN-MADE & VENDOR-MADE ATTRIBUTES’ is closed to new replies.
