Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Various bugs and issues
- This topic has 3 replies, 2 voices, and was last updated 7 years, 6 months ago by
- July 3, 2018 at 6:58 am #25817
d-n-13
ParticipantHello good wcfm team,
I have a list of issues I will list them all in one topic easier that a topic for each, if it’s okay.
1- Admin > Vendors > Vendor page > membership section shows wpml errors, (check 1st screenshot).
2- Translated products price seems not consistent with original products, sometimes they change sometimes they don’t, sometimes they change to old price, it was a bit confusing I can’t confirm if it is a bug or updating the tables are just slow. (check 2st screenshot).
3- Exporting Excel or CSV doesn’t show more than 10 rows, I hope we can export all data for advanced analysis.
4- Memberships still shows wrong numbers of vendors, I disabled all but 1 vendor. I think it shows the number of times vendors subbed to that membership ? (check 3rd screenshot)
5- Subscribe button appearing left (not centered) for me, I haven’t done any CSS changes (check 4th screenshot)
6- How does refund work exactly ? I am used to Dokan refund system where vendor request a refund from admin and set the amount refunded too, with or without shipping.
In WFCM I cannot figure it out the refund workflow exactly, It seems the vendor refunding directly, it is not bad, it makes it easier for admin, but A- There is no warning telling the vendor he cannot undo this action later. B- vendor cannot specify amount/with or without shipping/ what if there are many items ? C- WooCommerce Net-Sales didn’t change after refunding D- Can I prevent vendor from refunding, in case the current system doesn’t work properly ? Am I mis-understanding the refund system ?
Kind Regards,
You must be logged in to view attached files. - July 7, 2018 at 10:48 am #26037
1. I am getting this – http://support.themeblvd.com/forums/topic/wpml-sitepress-php-error-on-backend-due-to-layout-builder/
What is your WPMl version? Are you getting the error under Vendor -> Profile -> Membership ?2. That’s strange! Product price displayed from WooCommerce.
3. Umm … You may export page wise, but all data export at a time is not possible right now.
4. Yeah right, for disabling a vendor it has an issue. We will resolve this in next update.
5. I think it’s because of theme’s CSS. Your theme always aligned button at left.
6. Did you checked that particular order after vendor marked that as “Refunded”?
- July 7, 2018 at 2:52 pm #26041
d-n-13
1. Issue is gone with latest update
2. *I will check later*
3. It will be very helpful to export data for analysis + validation with accounting department, is there any other way to export sales with vendors names and ideas ? most importantly is should have vendors balance and withdraw history.
4. good to hear
5. Issue is gone with latest update
6. *I will check later*
I will check 2 and 6 later and update you.
Kind regards for the best support team
Khalid - July 8, 2018 at 4:49 am #26060
Yeah sure, take your time.
- The topic ‘Various bugs and issues’ is closed to new replies.
