Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Vendor Catalog
- This topic has 1 reply, 2 voices, and was last updated 5 years, 8 months ago by
Sarmistha Chakraborty.
- June 3, 2020 at 7:38 pm #138088
AW
ParticipantHi there
I just purchased the Ultimate version, I think WCFM is the best multivendor market place!
COuld you please provide a recommendation, in how to setup a lot of products from admin side, so that Vendors may “add to my store”, but with the intention that admin will not sell this product.
For example, I would like to create Product A, which multiple vendors can create.
The problem is Product A will not be sold by admin, only vendors. The solutions to hide Product A by Admin, is to hide from store catalog, but it is then not available to select by vendors. Also, if I make the Stock Level 0 (and hide out of stock products), then it is also not available to select by vendors.
To summarize, I would like to provide a pre-built catalog of items that vendors can choose from, and I hope you have a recommendation for doing this.
Alex - June 4, 2020 at 1:06 pm #138266
What you can, the admin will add products without price/zero price(those products will not display front-end) then the vendor can “add to my store” those products, and sell from his store page/front-end.
To hide from front-end no price and also which price is 0 products, add below code in your theme’s functions.php –
add_action( 'woocommerce_product_query', 'wcfmwp_hide_products_without_price' ); function wcfmwp_hide_products_without_price( $q ){ $meta_query = $q->get( 'meta_query' ); $meta_query[] = array( 'key' => '_price', 'value' => '', 'compare' => '!=' ); $q->set( 'meta_query', $meta_query ); }Ref- https://react2wp.com/woocommerce-hide-products-without-price-simple-fix/
