Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Vendor dashboard slow
- This topic has 26 replies, 2 voices, and was last updated 6 years, 3 months ago by
ciccupio97.
- April 27, 2020 at 9:12 am #123513
ciccupio97
ParticipantGood morning dear all,
since i’ve installed you plugin, when vendor try to load his dashboard nothing happen.
Well it never load and nothing is possible to do.
I’m using your plugin with Martfury theme of themeforest. I’ve tryied to change a theme too but nothing. Always the same.How is possible to fix it?
Regards - April 27, 2020 at 9:38 am #123524
KeymasterHello,
Thank you for contacting the support and sorry for any inconvenience that might have been caused due to that.
Assuming you are using the latest version of all the plugins and the themes (please update if not yet), it could be a conflict with one of the plugins or the theme you are using.
To determine that, please follow this awesome troubleshooting guide from here:
https://rankmath.com/kb/check-plugin-conflicts/Only the site admin would know and your users won’t be affected by this troubleshooting.
Please let us know if you find the cause.
Looking forward to helping you.
- April 27, 2020 at 9:57 am #123525
ciccupio97
ParticipantHi, yes of couse theme and all plugin are up to date.
I’ve done the procedure illustres on link you’ve sent to me.
Once i active wcfm frontend manager start back the problem. - April 27, 2020 at 9:58 am #123527
ciccupio97
ParticipantThis reply has been marked as private. - April 27, 2020 at 10:57 am #123546
ciccupio97
ParticipantPlease note too that an internal server error occure when trying add product from frontend.
Screen error attached
Regards
You must be logged in to view attached files. - April 27, 2020 at 11:00 am #123548
ciccupio97
ParticipantThis reply has been marked as private. - April 28, 2020 at 12:19 am #123858
ciccupio97
ParticipantGood evening Sir i’ve fixed problem. I’ll explain you shortly.
I’m Facing on other big problem.
After a New order, vendors And customer don’t receive the email order resume how can i fix it? - April 28, 2020 at 1:58 am #123909
ciccupio97
ParticipantWell, Good evening back dear all,
I’ve fixed loading page time increasing value on php.ini file as per screenshoot value, clearing all tansiet and trash data drom database, eliminating Redux Framework and I’ve replaced it with Kirki Customizer Framework and i’ve deactive envato market plugin for theme update. I’ll activate Envato Market Plugin only when I’ve an update available for theme used for the minute needed for update the theme.
Big problem now is when vendors have a new order no e-mail will be send to vendors email with parent or sub-parent order. Only a notification has been sent to fronted dashboard.
This is a big problem. It’s really impotant for vendors receive an email when a new order has been made.
Look that order email must be sent only to:
– vendors of product bought by customer and not for whole vendors registered on the web site;
– Admin of website;
– customer, owner of the order.Look that once customer complete his payment to checkout with PayPal system, once he push the link for come back to the web site, all product buyed remain in the cart for new order. Will be better that once checkout procedure is completed, cart must reset automatically.
Please, is really important to fix it.
Thank’s for your support
You must be logged in to view attached files.- April 28, 2020 at 1:59 am #123911
ciccupio97
- April 28, 2020 at 7:32 pm #124288
I’m really amazed how you have troubleshoot the slow loading issue and find the solution. I’ll also taking this note, if in future I run across a similar issue.Coming to the email not receiving by vendors issue, please install https://wordpress.org/plugins/wp-mail-logging/ plugin and check from it’s log if the vendor email is getting triggered or not. If yes, then there might be a problem with your email server and you’ll then need to contact your hosting provider.
Sometime, the email goes to the spam folder so check that too. You can use https://wordpress.org/plugins/easy-wp-smtp/ plugin which can solve many email related issues.
- April 29, 2020 at 11:57 am #124516
ciccupio97
ParticipantI’ll test it and i’ll come back on a while with news
- May 5, 2020 at 2:06 am #126732
ciccupio97
ParticipantHi dear, finally it is working. i’ve discussed it with my provider.
Well, is possble to define general delivery boy working for me and not for vendors?
is possible to auto assign order deliver to delivery boy dipending on the zone of delivery?if yes how?
if not it could be a good improvement for wcfm - May 5, 2020 at 6:23 pm #127031
KeymasterHello,
Yes it’s possible to add delivery boys for the admin. If you don’t specify any store than your vendors can’t assign that delivery person but you can. Auto assignment is not supported. I’ll take a note of this suggestion.
Thank You! - May 6, 2020 at 5:44 am #127207
ciccupio97
ParticipantI can assign manual delivery boy from admin panel to vendors order?
- May 6, 2020 at 6:31 am #127214
ciccupio97
ParticipantThis reply has been marked as private. - May 6, 2020 at 7:45 am #127230
ciccupio97
ParticipantThis reply has been marked as private. - May 6, 2020 at 11:13 pm #127642
Admin can assign delivery boy to vendor orders. Admin being a super user can do everything a vendor can do.
Though some part of your query is not possible right now, like auto assignment. As of now, your admin has to manually manage these things.
Thank You! - May 11, 2020 at 11:54 pm #129746
ciccupio97
ParticipantThank’s to you for now. What about POS? Is possible to configure a POS that it not create an order but only update quantity stock using a rapid barcode scanner?
- May 12, 2020 at 2:10 pm #129979
KeymasterWCFM support https://wordpress.org/plugins/wepos/ plugin. No, special setup required for this. Just install this plugin and add it’s POS page under vendor dashboard using WCFM Admin Setting -> Menu Manager
WooCommerce POS addon – https://wordpress.org/plugins/woocommerce-pos/ is also supported but this has to be set up to your site to make this functional for your vendors. We could help you in this, if interested you can contact us here – https://wclovers.com/woocommerce-multivendor-customization/
Now, I don’t know if any of the plugin I mentioned supports ‘barcode scanner’ or not, if they do then it can work with WCFM.
Thank You! - May 12, 2020 at 2:43 pm #129991
ciccupio97
ParticipantThank’s for your reply. I’ll test it. Is possible to disable function of that wepos of create an order? What I want to do is to not give possibility to vendors to not create an order into the system but i want give possibility to them to use it only for update his/her stock inventory quickly using a frontend.
Means if Vendor A receive sell on his offline shop items x, y and z, quickly he can update his inventory searching them using barcode scanner. Or you have a different solution about it?
- May 12, 2020 at 7:31 pm #130062
KeymasterThis feature is not supported in wePOS. So only stock update will not be possible. The purpose of any POS is easy offline sale, so I don’t think you will get such settings in any POS plugin.
Thank You! - May 28, 2020 at 3:58 pm #136163
ciccupio97
ParticipantThis reply has been marked as private. - June 4, 2020 at 2:04 pm #138282
ciccupio97
ParticipantDear Keymaster, may you help me please?
- June 5, 2020 at 7:54 pm #138833
KeymasterThis reply has been marked as private.- June 5, 2020 at 11:35 pm #138921
ciccupio97
- June 6, 2020 at 11:43 am #139020
ciccupio97
- The topic ‘Vendor dashboard slow’ is closed to new replies.
