Vendor products shortcode
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Vendor products shortcode
Viewing 5 reply threads
    • #36020
      Veronik
      I need to show the products for specific providers on a page; I would like to know if there is a shortcode available like this one: [wcfm_store_info id=”3″ data=”products”].
      Thanks in advance 🙂
    • #36126
      There has some widget for the purpose, do you have checked those?
      But those widgets only works in store page sidebar.
    • #36310
      Veronik
      I need to display the vendor products in a regular page but identified by vendor.
    • #36324
      Those widgets works in store page and in single product page.
      Between, what kind of display you are looking for here?
    • #36399
      Veronik
      I need to display the vendors products in regular page.
      Example:
      Homepage: Featured Vendors
      Vendor A:
      product1, product 2, product 3
      Vendor B:
      Vendor C:
    • #36428
      I understand your requirement.
      Which theme you are using?
      Do you have any idea whether your theme has any such products short code?
      If so, then we just to have to add support of “author” for that short code!
  • The topic ‘Vendor products shortcode’ is closed to new replies.
