Black Friday
04Day 22Hr 01Min 39Sec
Black Friday
Vendor profil setting not working
Viewing 8 reply threads
    • #24712
      elricka.lamy
      The plugin is still very nice and work well with WC Vendor (free) but since some update the vendors can’t manage their profil.
      The profil tabs are not working and there is no submit button displayed to save.
      I tried to see with css but can not find the solution.
      Also, the profil picture is not displayed and the existing ones was erased.
      Some help please ? 🙂
    • #24721
      Thanks for get in touch with us and I am really sorry for the inconveniences.
      I think there has some JavaScript errors in the page, can you please check this in Google Chrome Browser console?
      It will be more helpful if you share a demo vendor access with us to check the issue.
      Between, if you have caching then please clear cache once and take a look.
    • #24727
      elricka.lamy
    • #25042
      I am sorry for delayed reply.
      I found that, in profile page some JS error is there from theme JS file.
      Can you please WC Logs if there any error regarding this at wp-admin -> WooCommerce -> Status -> Logs
    • #25299
      elricka.lamy
      The JS error is a problem but not the problem with the profile setting 🙁
      So viewing the logs, there is a plugin conflict with WooCommerce Appointments.
      When I disable it, everything in profile works well.
      Do you think you could help me ?
    • #25300
      I will definitely resolve the issue for you.
      Can you please contact us directly here – https://wclovers.com/contact-us/
      Between, what is your WC Appointment plugin version?
    • #25301
      elricka.lamy
      You are so fast, Thanks !
      I just send you a message.
      For information I used the version WooCommerce Appointments 3.6.3.
    • #25304
      elricka.lamy
      Great, this is resolved !
      Your plugin and the staff are defintly the best 🙂
    • #25305
      You are welcome 🙂
      If you ever get a chance then please add a review for me – https://wordpress.org/support/plugin/wc-frontend-manager/reviews/
  • The topic ‘Vendor profil setting not working’ is closed to new replies.
