vendor registration not working
Best Multi Vendor Marketplace Plugin for WordPress Forums WC Vendors vendor registration not working
Viewing 12 reply threads
    • #115174
      aman147
      Hi
      I have installed the wcfm on the localhost. I was able to add a few vendors till tomorrow. But suddenly vendor registration stopped working.
      whenever I tried to open the link “vendor registration” it goes to login page.
      Please help me.
    • #115291
      Have you added any custom code snippets in your site? Please save once your site permalinks from settings.
      Thank You.
    • #115334
      aman147
      Hi
      Thanks for the quick reply.
      I have created and activated a child theme. Now when I again shifted(activated) the main theme this problem still not solved.
      What should I do now?
    • #115896
      Ok. Which theme are you using?
      Can you check once,
      Firstly de-activate all others plugins. Only active WooCommerce & our WCFM plugins(updated versions).
      And check once your “vendor registration” page have this “[wcfm_vendor_registration]” shortcode or not.
    • #116618
      meyou
      Hello, my wcfm vendor registration page is not working. It keeps hovering when a vendor tries to submit their details without any action. My dashboard pages are set currently, yet the problem persists. Please help.
      • #116834
        Share your vendor registration page URL, then we can see the issue then guide you accordingly.
        Before that please check once only active WooCommerce and our WCFM plugins, and default wordpress theme, you still have same issue or not.
    • #116841
      meyou
    • #116906
      meyou
      Did everything as instructed in the link you sent, yet the problem persists
    • #116999
      meyou
    • #117163
      We have checked your site.
      Actually this issue might be popping up because there was a problem in site setup, as a result the ajax file is getting an 404 error(PFA), it seems like this isn’t our plugins problem, and this is coming from elsewhere due to wrong setup. Kindly check the same.
      As we mentioned previously please check once only active WooCommerce and our WCFM plugins, and default wordpress theme (we are unable to access wp-admin dashboard), and check you still have same issue or not.
    • #117592
      meyou
      I didn’t get to see your last message because it was marked private. Want to confirm if you have seen the issue with it
    • #118183
      meyou
      Hey, seems what you did worked! Can now register, problem I have now is that vendors are registered as subscribers, how can I rectify this? Thank you
    • #118225
      meyou
    • #118230
      meyou
      It’s fixed, thanks for the prompt response
  • The topic ‘vendor registration not working’ is closed to new replies.
