Poila Boishakh
Celebrate Poila Baisakh with upto 20% OFF - A Fresh Start, A Great Deal!
02Day 23Hr 22Min 03Sec
Poila Boishakh
Vendor Shop
Viewing 11 reply threads
    • #29126
      Netta
      Thank you for an awesome plugin! I just have a situation going on with the vendor product images in the vendor store as the images are very huge and not side by side. Any suggestions on how to fix this will be very appreciated. Thanks.
    • #29155
      Thanks for get in touch with us and really pleasure to have such appreciation.
      Can you please show me screenshot of this or best to have such a store URL.
      Don’t worry, this is a small CSS fix I guess.
    • #29255
      WWW
      I think Netta has a similar issue to mine. I think the default vendor store page is not a best looking one. Here is a screenshot of my demo site vendor store page in a second attachment.
      What I am looking for is a custom store page similar to my rehub theme original looks like the first attachment.
      Would be awesome if I could set up a custom vendor store instead of the original one. I am not a coding expert, but perhaps a snippet for this purpose is possible?
    • #29287
      As I see in screenshot your products are displayed perfectly in vendor store page.
      I guess, you didn’t add anything in store page. Please check this – https://wclovers.com/knowledgebase/wcfm-marketplace-widgets-short-codes/
      Off course you may add such store info in sidebar using short code – [wcfm_store_info data=””]
    • #29399
      WWW
      Thanks for reply. The shortcodes in text a widget sidebar do not work for me. I double checked and there is no typo’s or anything. Overall, the store layout and the stores page with a shortcode [wcfm_stores] is way too space wasting in my opnion.
      If you could provide me a solution how could I use my custom theme based layout pages for vendor shop and vendors list, that would be just awesome. Please.
    • #29401
      d-n-13
      “Thanks for reply. The shortcodes in text a widget sidebar do not work for me.”
      There is a typo from wcfm knowledgebase page
      please change the quotations from
      to
    • #29402
      WWW
      OK, thanks I got the side bar solved. The problem was in quotation marks which are not the same as mine if copy-pasted. The rest I can probably get better with some css, but I would definitely prefer my own custom pages.
    • #29403
      d-n-13
      “[wcfm_store_info data=””]”
      I guess the issue in wclovers.com font changing the quotations, looks like people cannot copy from wclovers.com they have to type quotations manually.
    • #29604
      Really sorry for the trouble – quotations are problem. These are not coding single quote!
      You may off course copy but please change quotations.
    • #29894
      rezabadoella
      Guys some help please, I have the same issue but I do not see the difference in:
      to
      It looks the same…
    • #29911
      d-n-13
      Hello Rezabadoe
      “You may off course copy but please change quotations.”
      You have to type the quotations manually, wclovers forms doesn’t show the quotations correctly.
      see screenshot 2nd one is correct : https://www.dropbox.com/s/0togj4s1veorj6y/quotations%20problem.JPG?dl=0
    • #29991
      Please copy this – [wcfm_store_info data=""]
      It’s also updated in documentation.
  • The topic ‘Vendor Shop’ is closed to new replies.
