Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Vendor Store settings and Front-End issues – (FlatsomeTheme)
- This topic has 5 replies, 2 voices, and was last updated 8 years ago by
- September 19, 2018 at 3:30 pm #32010
kameleon1er
Guest– Store Side Bar :
• Position : left or right => can’t manage position with my WordPress Apparence options.
• no matter if checked or not in « Vendor store area » still display in the front store view.
• Child categories do not display correctly ; I have Photography category (parent) and 2 child-category (Colors and Black-and-White), only Black-and-White appears in the side-bar (example : https://lucifart.com/store/nabil)– Products per page :
•Doesn’t work, I put setting « 8 », on front site, display always 10 products (example : https://lucifart.com/store/sandybee/)
•and if Vendor got more than 10 products : pagination don’t work properly : always 10 products per page (2 products missing in the page grid per page (example : https://lucifart.com/store/nabil)
• More than 8 products on store page, left side-bar background don’t cover all the page (too short in height)– Marketplace Shipping (Enable this to allow your vendors to setup their own shipping by country)
• unchecked and yet still visible on the order page (client checkout) => « StoreName-Shipping » Flat: 0.00 €, that’s not true.– Override premium child-theme : could you give an example please ? With Flatsome by example 😉
Thanks a lot.
- September 19, 2018 at 3:36 pm #32011
kameleon1er
GuestMmmm… Maybe it’s not in the good forum, better in WCfM Forum… Sorry 🙂
- September 19, 2018 at 8:09 pm #32033
Thanks for get in touch with us, let me clear your queries.
– Store Side Bar :
• Position : left or right => can’t manage position with my WordPress Apparence options.– Right, we will add setting option for this in coming update
– Not getting this, “front store view” means? Actually, it’s not possible to add theme setting support in general as all themes work with different setting options. Such things should be customized or override templates and edit as your own.
– Store categories can’t be show like that as there is no all categories, possible a child category is there but not the parent one, then how such display can be supported. You may use default WC category widget as well, but the filter will not work as per store.
•Doesn’t work, I put setting « 8 », on front site, display always 10 products (example : https://lucifart.com/store/sandybee/)– WCFM marketplace has setting for this at global and vendor level, please use that – https://ibb.co/mg24CK
– Just in your site, pagination is there – https://ibb.co/bHFkKz
– Will take care of this in next update
– Yeah, you have disabled vendor’s country wise shipping options and not the shipping. What you want to do here? Not want to show “Storename”?– Override premium child-theme : could you give an example please ?
– Yes, you may off course override WCFM Marketplace templates under your child theme.
Check at “wc-multivendor-marketplace\views\store\” -> Copy templates into “child theme\wcfm\store\”Thank You
- October 5, 2018 at 4:17 pm #33363
Kameleon1er
GuestHi, ok, I’ve check each point, could you maybe also move this post in the correct forum (WCfM standard forum) 🙂 :
– Store Side Bar :
#(done ! thanks) • Position : left or right => can’t manage position with my WordPress Apparence options.
– Right, we will add setting option for this in coming update• Child categories, still have an issue, I well use WCfM-widget-category but only the Second one is displayed.
#(done ! thanks) •Doesn’t work, I put setting « 8 », on front site, display always 10 products (example : https://lucifart.com/store/sandybee/)
(yes it works, need to put the number in : store-manager/vendors-manage/ => Vendors => Visibility Setup => Products per page
– WCFM marketplace has setting for this at global and vendor level, please use that – https://ibb.co/mg24CK#(done ! thanks) • More than 8 products on store page, left side-bar background don’t cover all the page (too short in height)
– Will take care of this in next update - October 6, 2018 at 11:10 am #33412
– Yeah right, we have made this for two level right now.
Will extend soon, actually we are still testing this with different theme!i will update you on this.
- October 31, 2018 at 4:36 am #35358
– WCFM Marketplace 1.2.1 has just released and this has been taken care of.
- The topic ‘Vendor Store settings and Front-End issues – (FlatsomeTheme)’ is closed to new replies.
