Best Multi Vendor Marketplace Plugin for WordPress › Forums › Product Vendors › Vendor to only Edit Existing Products. Product Tab not showing on WCFM.
- This topic has 5 replies, 3 voices, and was last updated 8 years, 9 months ago by
Simha.
- December 8, 2017 at 7:51 am #16637
hello1
Currently having an Issue whereby the ‘Products’ tab is only appearing for our vendors if we give them the ability to Submit or Publish their own products, we want them to only edit their existing Product, however, when this capability is ticked alone, the tab does not appear.
For context, we have created an online marketplace using Product Vendors where each vendor acts as a sole trader selling only themselves as a bookable product for work (therefore each vendor only has the 1 product being themselves). We need them to be able to update their product (bookable self) so they can change booking availability when needed, we don’t want to give them the option to add or even submit new products as this could lead to confusion.
I have attached a screen shot of our capabilities to aid in my comment. Many Thanks.
You must be logged in to view attached files. - December 8, 2017 at 9:03 am #16640
I understand your concern. Actually, currently there is no such capability to block only “Add New Product” for vendors using WCFM – Ultimate. It comes with WCFM – Groups & Staffs actually.
Just relax, we will add that option in WCFM – Ultimate as well in next update.
“Submit Products” capability is essential to allow Products to vendors, as you disabled that so there is no Product option in Vendor dashboard.
As you told me your system is very specific and vendors are only with one product then you may also use “Product Limit” option for now, set it 1. Then vendors can edit there existing product but not able to add anymore.
- December 13, 2017 at 8:16 am #16820
WCFM 3.3.5 has just released.
Now you have a another separate capability option to disable only “Add Product” for your vendors.
So for your case, keep “Manage Products” ON and “Add Product” OFF will meet your desired requirement.
Please know mw is this works for you or not
Simha - December 13, 2017 at 8:17 am #16821
Simha - December 14, 2017 at 8:23 am #16870
hello1
ParticipantHi Simha (and the rest of WC Lovers),
This works perfectly. Thank you for including this as part of an update and I personaly commend you on the very fast turn around time.
It is great to see the passion and the high level of detail you put into this product, it is refreshing to see that you are so willingly to continually improve your product as well rather than having it as a ‘set and forget’ model.
This alone proves to me that procuring your paid version of the front end manager was a very sound investment!
Thanks Again!
-Braydn - December 15, 2017 at 3:10 pm #16929
Simha
Pleasure and always welcome.
Really really pleased with your heartiest appreciation.
We have reacently launched another add-on for vendors membership/subscription. If required you may also take a look into this, it’s even totally FREE – https://wordpress.org/plugins/wc-multivendor-membership/
Thanks again.
Simha
- The topic ‘Vendor to only Edit Existing Products. Product Tab not showing on WCFM.’ is closed to new replies.
