Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Vendors can't add shop banner
- This topic has 3 replies, 3 voices, and was last updated 7 years, 6 months ago by
- September 18, 2018 at 2:56 pm #31945
Jon
GuestHi, I have WCFM and your analytics addon running with WC Vendors Pro. My vendors can add a shop logo but when they click the branding tab the message ‘ WCV Pro Settings: Please ask your Store Admin to upgrade your dashboard to access this feature.’ appears. I have set everything in the WC Vendors setting that I can see but still they can’t add banners. If I disable the plugin and just use the standard WC Vendors dashboard they can add a banner but I then can’t use the analytics. Am I missing something obvious? do I need to purchase WCFM ultimate to have the ability to add a banner?
Thanks Jon
- September 18, 2018 at 8:11 pm #31968
Do you have WCFM Ultimate (https://wclovers.com/product/woocommerce-frontend-manager-ultimate/)?
If not, then it’s essential to access WC Vendors Pro features on WCFM dashboard.
- September 19, 2018 at 2:42 pm #32007
jhweb
ParticipantAh I see, yes I just had the free WCFM. Just purchased Ultimate and all is working fine.
Thanks 🙂 - September 19, 2018 at 7:20 pm #32026
MemberGreat, you are welcome 🙂
- The topic ‘Vendors can't add shop banner’ is closed to new replies.
