vendor's own Sub-domain and single product multiple vendor
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › vendor's own Sub-domain and single product multiple vendor
Viewing 1 reply thread
    • #34538
      Jun
      Hi WC lovers
      I plan to build a website. It will be multiple vendors and they basically sell the same products.
      The website subdomain URL that the customers entered will direct the customers’ purchase to the corresponding vendor.
      For example:
      https://www.mydomain.com is my website. It has three products.
      If the customer goes to https://vendorA.mydomain.com. It has the same three products. Everything the customer purchased will go to vendor A.
      If the customer goes to https://vendorB.mydomain.com. It has the same three products. Everything the customer purchased will go to vendor B.
      Everything else on either website looks the same as the https://www.mydomain.com. The only difference is the subdomain.
      It’s kind of affiliate vendor URL and single product multiple vendor functions.
      Can I use your plugins to do that? Or should I contact the customization?
      Jun
    • #34569
      I understand your concept but certainly this option is not yet available.
      As per my knowledge there is only one multi-vendor plugin which support this, it’s from webkul.
      You may take a look at it.
  • The topic ‘vendor's own Sub-domain and single product multiple vendor’ is closed to new replies.
