Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Vendors store on mobile.
- This topic has 4 replies, 2 voices, and was last updated 7 years, 10 months ago by
- December 14, 2018 at 7:58 pm #40051
Gabriel Onyejegbu
I observed that when I view a vendors store on a mobile phone it shows the vendors products one on a row. I would love if the vendors store could be set to set more than 1 product on a row.I also observed that the widgets on the vendors store show below the products. The entire sidebar shoes below the products. I will like it to be in a navigation filter so that user can choose to view it from the top of the page.
- December 15, 2018 at 6:46 am #40084
– Does your theme template support this? How you are getting WC default store page view in mobile?
– So you want to have sidebar first and then products list in mobile, right?
- December 15, 2018 at 8:59 am #40112
Gabriel
GuestHi, I have solved the first issue.
About the second, I want the vendors categories and product search to show first before products. - December 15, 2018 at 9:01 am #40113
Gabriel
GuestHi, downloaded and installed the yith brand plugin, but I am not able to create a new brand from wcfm but I can create a new brand from the wp backend.
I need my vendors to be able to create a new brand bwhe ever they need to from the frontend. - December 15, 2018 at 10:00 am #40117
Well, your vendors off course able to create Brand from product manager screen.
Hope you are using product taxonomy check box select mode!
- The topic ‘Vendors store on mobile.’ is closed to new replies.
