WC – Product add-ons
Viewing 3 reply threads
    • #126665
      elmer
      I’ve just purchased the WCFM ultimate and the WC Product add-ons from https://woocommerce.com/products/product-add-ons/
      I have two questions:
      1) When adding a Product add-On per product in the store manager it wont display al the fields. Scrolling is almost impossible, the last input fields are only visible when you Tab trough the input fields. How can I lengthen the vertical view in such a way that I can view all the fields.
      2) When adding a product I get a popup for the add-ons like I expected, I add the products to the cart but it wont show up in the cart.
      with regards Elmer
    • #126738
      elmer
      disregard the second point. It seems that another plugin was causing my problems, I’m finding out which one.
    • #126870
      >>Can you please share us one vendor access of your site, along with site url. Then we can check the issue and guide you accordingly.
      When sharing the access, please don’t forget to mark the reply as private.
    • #126915
      elmer
  • The topic ‘WC – Product add-ons’ is closed to new replies.
