Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › WC Ultimate – ACF Post Taxonomy Integration
- This topic has 9 replies, 2 voices, and was last updated 7 years, 7 months ago by
- August 6, 2018 at 10:15 am #27754
rap
Firs of all, I am not a programmer, my knowledge is quite limited, so sorry if I don’t express my problem properly.
I am using WC-Ultimate and its integration with ACF. I am trying to create a group of fields to fill by my Vendors when uploading products, which will appear after they select a category for the product, using the conditional logic of the field groups of ACF to achieve that.
When using WCFM, this feature works fine for categories up to the second level (example: post taxonomy equals to -Home & Garden –Cooking tools) however, if I select a third level category as the condition for the group field appearing(Ex: post taxonomy equals -Home & Garden — Cooking tools —BBQ Grills) the condition is not read, and the group field appears in all the time, ignoring if the category is selected or not.
I believe this error is caused by the way WCFM organizes the product categories, reading only up to the second level(Category,sub-category), as this error doesnt happen if I upload a product from the back end. I also realized that the category list only collapse one level, loading all subcategories at the same time, as in picture attached, which lead me to thing I am right?
Can I anyone let me know if this can be solved easily?
Thank you in advanced for your help guys!
You must be logged in to view attached files. - August 6, 2018 at 11:00 am #27769
Thanks for get in touch with us and I understand your issue.
We will definitely resolve this in next update.
- August 6, 2018 at 11:06 am #27770
rap
Thank you for your answer.
Sorry If I look impatient, is there any programmed date for next update?
If it is going to take long, would this problem be solved if I create a new taxonomy with all product categories using Toolset, and then set that taxonomy as the condition for the group to appear? Or would I have the same issue?
I may consider buying toolset if necessary, but I would wait if you recommend me to.
Thanks again!
- August 8, 2018 at 7:33 am #27914
WCFM and WCFM Ultimate new version has just released.
Kindly update yours, then issue has been already resolved.
No need to install Toolset.
- August 8, 2018 at 12:31 pm #27929
rap
Thank you so much for the fast work,but I already updated my plugins, and I still have the same issue:
Example: I have 3 level product category (I find them under Post Taxonomy in ACF)
-Houseware & Garden
—–BBQ
———BBQ Grill
———BBQ Tools
———BBQ AccessoriesIf I set up the conditions of my field group in ACF as
Post Type equals Product
Post Taxonomy equal —–BBQThe group field appears/dissapears when I select/unselect the –BBQ from the category list during product creation in WCFM.
However, if I set my rules as
Post Taxonomy equal ———BBQ GrillWCFM ignore my last rule “Post Taxonomy equal ———BBQ Grill”, and show the group field in product creation all the time, because of “Post Type equals Product”.
Can we get it to read my 3rd level category and it doesn’t ignore “Post Taxonomy equal ———BBQ Grill”?
Thank you again for your help and effort.
- August 9, 2018 at 2:54 pm #28040
Do you have updated WCFM Ultimate to 4.2.3 ?
Please update this and take a look.
- August 10, 2018 at 3:12 am #28121
rap
Okay, I know what is happening, my bad.
I am actually using ACF Pro, didn’t think it would work different. I tried installing ACF free version, and it is working smoothly (good work there!).
Do you think this could also be implemented for the pro version?
Thank you.
- August 10, 2018 at 6:00 am #28125
Umm … this is already implemented for ACF Pro.
Well, we will test this once again for ACF Pro.
- August 10, 2018 at 7:18 am #28143
rap
I am not sure, I’ve tried everything, but while it works on the ACF free version, it doesnt on the ACF Pro.
See attached.
Thank you.
- August 10, 2018 at 7:20 am #28145
We will check this for ACF Pro, may be new version causing some issues.
- The topic ‘WC Ultimate – ACF Post Taxonomy Integration’ is closed to new replies.
