Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Wc Vendors page (list of vendors) not updating
- This topic has 12 replies, 3 voices, and was last updated 7 years, 7 months ago by
- August 22, 2018 at 11:28 pm #29260
hkgemnet
ParticipantAs i am storing vendor store informations via front end manager,
vendors listing page is not being updated with new vendors.I somewhere saw that wc vendors needed to save the store information first
to get the new vendors in vendors list.As store manager replaced pro dashboard,
now vendors page is not showing the latest information. - August 23, 2018 at 10:46 am #29336
We are looking in to this.
Between, you may try WCFM own multi-vendor module as well – https://wordpress.org/plugins/wc-multivendor-marketplace/
It has many more features and much more flexible to use – https://wclovers.com/blog/woocommerce-multivendor-marketplace-wcfm-marketplace/Thank You
- August 23, 2018 at 1:36 pm #29356
hkgemnet
GuestNo. I already have wc vendors implemented.
What do you mean by ‘We are looking in to this.’?Is it bug from your side?
Isn’t it already wc vendors compatible? - August 23, 2018 at 1:41 pm #29359
hkgemnet
ParticipantNo. I already have wc vendors implemented.
Isn’t it already wc vendors compatible? - August 25, 2018 at 7:08 am #29661
hkgemnet
ParticipantAny update?
Will it be fixed on next plugin update? - August 25, 2018 at 7:12 am #29663
Yeah sure, we will resolve this in next update as well.
It was working perfectly, possibly WC Vendors latest updates causing some issues.
We are checking and will resolve in next update.
- August 25, 2018 at 3:25 pm #29704
I have debugged this and found that everything is just perfect.
I think you have set vendor list page with short code –
[wcv_vendorslist]Now, WC Vendors display vendors in that list page if that vendor has any products. So you are not getting new vendors just after registration, add a product with that vendor account and you will see than vendor in that list.
There is an alternate of this as well, add this short code –
[wcv_vendorslist show_products="no"]
This will show you all vendors, whether they have any product or not!Please know me is this resolve your issue or not?
- August 27, 2018 at 5:39 pm #29864
hkgemnet
ParticipantSorry to say, still having the same issue.
No luck.Created vendor.
Added store informations.
Added product.Still no new vendors are showing on dealers (vendors) page.
Tried with your shortcode as well.
- August 28, 2018 at 3:35 am #29900
How you are creating product?
I mean, which registration form you are using?
- August 28, 2018 at 7:10 pm #30001
hkgemnet
ParticipantCreated product with fronted manager (your plugin).
Tried these shortcodes.
[wcv_vendorslist]
[wcv_pro_vendorslist]
[wcv_vendorslist show_products=”no”]
[wcv_pro_vendorslist show_products=”no”]One at a time.
Note: I am using wc vendors pro.
Tested again but no luck.
- August 29, 2018 at 8:14 pm #30142
It doesn’t matter from where you have created products.
You may create product from wp-admin are and assign vendor.I have tested this in our demo – https://ibb.co/e0Ugcp
http://wcvendors.wcfmdemos.com/my-vendors/Well, what it’s showing? Blank page?
Are you using any caching? Then please cleared that and check once.
Which theme you have? Possible to check using default or storefront theme?
one more thing, hope you are using all latest version of plugins.
- August 30, 2018 at 6:38 pm #30245
hkgemnet
ParticipantWCFM Forum :
‘How you are creating product?I mean, which registration form you are using?
which registration form you are using?’Me :
‘Created product with fronted manager (your plugin).’Your previous reply:
‘It doesn’t matter from where you have created products.
You may create product from wp-admin are and assign vendor.’I wonder why did you ask then how am i creating product!
‘I have tested this in our demo – https://ibb.co/e0Ugcp
http://wcvendors.wcfmdemos.com/my-vendors/’
– Well, after creating a vendor account does that vendor appear in that page?
Note: Somewhere i saw, wcvendors shows vendors only after that vendor account settings is saved from wc vendors dashboard.
My case: if i create a vendor, it doesnt immediately show up on vendors page. I need to save account details from wc vendros dashboard.
Only then vendors page shows list of vendors with the new one.WCFM issue:
As i am using WCFM, so there is no wc vendors dashboard. So no account settings is saved from wc vendors pro dashboard.
Hence, vendors page is not updating at all.Note: WC Vendors Pro and WCFM Ultimate : Using these plugins.
‘Well, what it’s showing? Blank page?’
– ‘Still no new vendors are showing on dealers (vendors) page.’
Already replied. Old vendors are shown there (their account details were saved by wc vendors pro dashboard: before installing your plugin)‘Are you using any caching? Then please cleared that and check once.’
– Well i use incognito window for testing. I dont think cache issue at all. Always use hard cache clear (Ctrl f5 for windows).‘Which theme you have? Possible to check using default or storefront theme?’
– Shopme theme (ShopMe – Multi Vendor Woocommerce WordPress Theme)
Checked with sotefront theme. Not showing all vendors. Same as previous theme (shopme).
Not a theme issue.Note: I am using level dealer instead of vendor. But user role level is still vendor.
‘one more thing, hope you are using all latest version of plugins.’
– Yes.Let me know if you need admin details.
I can provide as well. - September 3, 2018 at 6:04 am #30602
What is your site’s vendor registration process?
Are you using this plugin – “Indeed Ultimate Membership Pro”
I don’t think it’s WC Vendors compatible.
Well, if you are not using WCFM Membership for vendor registration then WCFM hs no control over vendor registration.
- The topic ‘Wc Vendors page (list of vendors) not updating’ is closed to new replies.
