Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Analytics › WCFM – ANALYTICS problem – database corruption
- This topic has 5 replies, 3 voices, and was last updated 6 years, 5 months ago by
- August 30, 2019 at 1:00 pm #79222
Oksana Grishchenko
After Installing WCFM – ANALYTICS for the first time, when i wanted to backup my site i received an error related to WCFM – ANALYTICS.
The site is OK but i can not backup my site. I’m using Godaddy for host and backup. I contacted them and they told me that the problem is not from their side.I checked the database i see this error :
[i2085810_wo1.wo_wcfm_detailed_analysis] Table is marked as crashed and last repair failed
[i2085810_wo1.wo_wcfm_detailed_analysis] 1 client is using or hasn’t closed the table properly
[i2085810_wo1.wo_wcfm_detailed_analysis] Size of indexfile is: 8325120 Should be: 1024
[i2085810_wo1.wo_wcfm_detailed_analysis] Found key at page -1 that points to record outside datafile
[i2085810_wo1.wo_wcfm_detailed_analysis] CorruptAlso this the error that appeared when i wanted to backup my site:
‘ MYSQL ERROR 144: Table \’./i2085810_wo1/wo_wcfm_detailed_analysis\’ is marked as crashed and last (automatic?) repair failedSELECT COUNT(*) FROM
wo_wcfm_detailed_analysis‘, ), )Please help!
Regards, - September 2, 2019 at 9:19 am #79576
– Do you have tried to run manual repair? If not, then please do this once.
- September 28, 2019 at 11:30 pm #84296
aghorbany
ParticipantThe manual repair did not work. Also, i used Goddady support team to look into the issue but no result from the too. At last i empty the [i2085810_wo1.wo_wcfm_detailed_analysis] in the database and it’s OK for now but i don’t know which data i lost.
Can you tell me please what was in [i2085810_wo1.wo_wcfm_detailed_analysis] and what i lost when i empty it?
Thank you! - September 30, 2019 at 12:10 pm #84491
Are you using WCFM – Analytics addon?
If not, then don’t worry about this!
- October 16, 2019 at 5:04 pm #87167
- October 18, 2019 at 9:39 am #87506
Please add this line to your site –
add_filter( 'wcfm_is_allow_wc_geolocate', '__return_false' );Add this code to your child theme’s functions.php
