Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › WCfM Auto Withdrawal bugs
- This topic has 2 replies, 2 voices, and was last updated 7 years, 7 months ago by
- April 6, 2019 at 12:56 pm #56496
S Suhendro
GuestIm using wcfm multivendor marketplace for woocommerce.
withdrawal is doing an auto-withdrawal, but yesterday I checked box for auto and uncheck its fine but today its doing autowithdrawal again.Try to reproduce it and its doing again and again no matter i changed on settings and tested.
Please help! Thanks
- April 6, 2019 at 4:00 pm #56506
Sandi S
GuestHi again,
tried to deactivate wcfm then delete all previous order and seems the withdrawal is fine and no auto approve anyomore, but I will test more to make sure. - April 7, 2019 at 3:44 pm #56670
– Well, it “Auto-withdrawal” setting checkbox is disabled then it will not generate auto-withdrawal request.
Between, be sure – you do not have enabled “Reverse Withdrawal” by mistake, hence normal withdrawal will not work!
– Sure, you can do this. Then you have to enable “Uninstall” checkbox at WCFM Admin Setting -> Marketplace setting before deactivate plugin.
Don’t forget to disable this after reinstall!Thank You
- The topic ‘WCfM Auto Withdrawal bugs’ is closed to new replies.
