Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › WCFM breaking WordPress?
- This topic has 4 replies, 3 voices, and was last updated 7 years, 5 months ago by
Bingal.
- March 18, 2018 at 10:26 pm #20515
omarmasrur
ParticipantAfter activating WCFM, if I make changes to child theme’s functions.php and try to save those changes…wordpress goes off and eventually returns with this message (instead of the usual “Filed edited successfully”):
“Unable to communicate back with site to check for fatal errors, so the PHP change was reverted. You will need to upload your PHP file change by some other means, such as by using SFTP.”
The problem disappears if I de-activiate WCFM.
To rule out theme conflicts, I switched theme to 2015 and the problem remains if WCFM is active and disappears when WCFM is deactivated. - March 19, 2018 at 9:53 am #20555
Omar
GuestI have also used health check plugin and enabling WCFM (free version) shows error in the loopback test category of the plugin.
- March 19, 2018 at 7:38 pm #20596
Bingal
Thanks for all this info.
“Unable to communicate back with site to check for fatal errors, so the PHP change was reverted. You will need to upload your PHP file change by some other means, such as by using SFTP.” – this is due to WCFM, something mysterious.
We are just testing all this and know you update soon.
Thanks again
- March 21, 2018 at 8:21 pm #20687
omarmasrur
ParticipantCan you please tell me when this will be fixed.
My development has frozen since I cannot edit functions.php file.
I really like your product and bought WCFM Ultimate.
How long do you think it will take to correct this problem?
tks
- March 22, 2018 at 6:13 pm #20729
Bingal
We have already fixed the issue and it will be part of WCfM next update.
I am really sorry for the inconveniences.
For the timing you may use this for editing your files – https://wordpress.org/plugins/wp-file-manager/
Thanks for your patience.
- The topic ‘WCFM breaking WordPress?’ is closed to new replies.
