WCFM Custom Fields – add to with short description on the store products page.
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › WCFM Custom Fields – add to with short description on the store products page.
Viewing 5 reply threads
    • #51119
      cousinr
      Hello… I use the Electro Theme, WooCommerce, WCFMU.
      How to add wcfm custom fields to the shop products page or the shop category products?
      My screenshots:
      1 ) https://ibb.co/CVfSWVS – i cant off the title on the display…
      2) https://ibb.co/TL5bH34 – my custom fileds settings – its ok.
      3) https://ibb.co/HGKM933 – how it looks on the product page – its ok.
      4) https://ibb.co/dbzvFRZ – how can I place my custom fields on the shop products page?????????
      i need a code in php? what should i do? help me please!!!
    • #51123
      cousinr
      Oh sorry….
      I meant that I want to do this. I want add custom fields in this place.
      https://ibb.co/r01QJQY
    • #51147
      Well, WCFM Custom fields by default display comes only for Single product page.
      Now, all these custom data stored as product meta, so you may display those any where as well.
      Hope you remember, you have specified a “name” for each field, that is meta_key in the database for that field.
      For this particular case it will be best for you to reach your theme author. They can suggest you the best possible way to show anything with their template!
    • #51164
      cousinr
      What does field as a group mean?
    • #51166
      Well, that is for “how you want to store meta fields in database” – as a group (array) or single element.
    • #51172
      cousinr
  • The topic ‘WCFM Custom Fields – add to with short description on the store products page.’ is closed to new replies.
