Diwali
03Day 08Hr 36Min 19Sec
Diwali
WCFM Default settings
Viewing 11 reply threads
    • #47374
      BODET
      Hi there,
      After moving my site from localhost:8888 to localhost:80, the default banners, images for vendors store are not found anymore.
      What I am missing, please?
      Regards,
    • #47448
      You possibly not updated site url form wp-admin -> Setting
    • #47467
      BODET
      I just went to dashboard->settings->General and changed WordPress address (URL) and Site address to http://localhost (there was http://localhost:8888).
      Everything works except the default banners, images, etc… for vendors store that are not found because wcfm continue to search them at localhost:8888.
    • #47468
      BODET
      And obviously I changed the ports in the MAMP configuration.
    • #47492
      Well, this is because WP store attachments URL in database – https://ibb.co/kBqzdMc
      Now, you have to change those in database as well.
      Well, there is a script available for the purpose – https://webcusp.com/how-to-change-wordpress-domain-url-with-this-free-php-script/
    • #47524
      BODET
      But after doing that, I have no image yet.
      <div class=”banner_img”>Naen</div>
      David DAVID
    • #47526
      Then be sure, those images are available in uploads folder.
      Also check at database for attachment urls, are those now right as per site’s URL or not!
    • #47529
      BODET
      All the URLs have changed. I can set the banner for example with an image from the upload folder.
      But my question was and is how to reset the settings to the defaults one where the plugin display a default banner when I do not set a custom one.
      The banner located in wp-content/plugins/wc-multivendor-marketplace/assets -> default_banner.jpg which is not in the upload folder…
    • #47530
      “The banner located in wp-content/plugins/wc-multivendor-marketplace/assets -> default_banner.jpg which is not in the upload folder…” – it’s not required to be in upload folder.
      Well, you may change default banner from WCFM Admin Setting -> marketplace setting tab
    • #47541
      BODET
      Yes, if I do not set a banner in marketplace settings tab, the default banner is not displaying!
    • #47542
      BODET
      As it was just after the installation of the plugin
    • #47549
      I think your site have messed up, why you not try with a fresh installation!
  • The topic ‘WCFM Default settings’ is closed to new replies.
