WCFM- Marketplace does not appear in my web
Viewing 3 reply threads
    • #55036
      Aleix
      Good Morning!
      I installed WCFM- Marketplace and the configuration went well. But the name of the vendor does not appear in my store:
      https://www.coolturemag.com/tienda/
      And on the vendor’s page, nothing appears to me, only the products:
      https://www.coolturemag.com/store/miqueljane/
      I’m using the template Javo Themes and Elementor.
    • #55037
      – Is this template created using Elementor?
      If so, then add this code to your child theme’s functions.php –
      add_filter( 'pre_get_posts', function( $query, $that = null) {
      	global $wp_query, $post;
      	$wcfm_store_url = get_option( 'wcfm_store_url', 'store' );
      	$store_name = urldecode( get_query_var( $wcfm_store_url ) );
      	if ( !is_admin() && $query->is_main_query() && !empty( $store_name ) ) {
      		$query->is_archive    = false;
      		$query->is_post_type_archive    = false;
      	return $query;
      }, 50, 2 );
    • #55054
      Aleix
    • #55059
      Aleix
      Solved!
  • The topic ‘WCFM- Marketplace does not appear in my web’ is closed to new replies.
