Holi
Celebrate Holi with vibrant offers! Get upto 25% OFF on all our addons.
01Day 01Hr 49Min 32Sec
Holi
WCfM – Membership using WC Products
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Membership WCfM – Membership using WC Products
Viewing 5 reply threads
    • #23183
      WCfM – Membership 1.3.0 has just released and now you may setup membership using WC products and use WC checkout for membership purchase, so no more limitation over payment gateways.
      Here is help guide for setup –
      https://youtu.be/SfOMIxNfr3w
      Please know us if you have any further suggestions on this!
    • #23540
      well, here is a confusion – is WCfM – Membership going to offer you creating subscription type products or not?
      – NO, off course not.
      For the purpose you have to install a subscription plugin for WC separately.
      You may install –
      1. https://woocommerce.com/products/woocommerce-subscriptions/
      OR
      2. https://wordpress.org/plugins/xa-woocommerce-subscriptions/
      Both are compatible with WCfM.
      Please reach us if you have any confusion regarding this.
      Thanks for being with us.
      WC Lovers
    • #26893
      Dan
    • #26968
      Can you please check, whether you have enabled “Approve” on for the membership level or not?
    • #27943
      JuanB
      Unfortunately this plugin was closed on August 2 on WordPress.org.
      Can you replace it with another one of good reputation and that is not as expensive as Woocommerce Subscription?
      Thank you.
    • #28045
      Opps! We had no idea about this.
      We will definitely look for alternate of this very soon.
      Between, do you have any suggestion or find any other solution yet?
      Then please know us as well.
      Thanks for the update.
  • The topic ‘WCfM – Membership using WC Products’ is closed to new replies.
