Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › wcfm redirect issue
- This topic has 6 replies, 3 voices, and was last updated 8 years, 6 months ago by
- April 12, 2018 at 6:58 am #21655
diky
Guesthy wcfm i install dokan but when start install wcfm my dokan dashboard always redirect to wcfm, how i can disable redirect so ican use boot of dasboard (dokan dashboard dan wcfm dashboard ) i try use this add_filter( ‘wcfm_is_allow_multivendor_dashboard_redirect’, ‘__return_false’ ); but its still not working. cn u halpme please
- April 12, 2018 at 10:45 am #21661
Well, I understand your requirement.
Kindly wait till the next update, we will add support of this so that you may able to access both the dashboard.
- April 13, 2018 at 8:36 am #21725
Kindly update your WCfM to 4.0.5 and you are able access this now.
- April 18, 2018 at 7:01 am #21976
hoangdvo00
Im working on Woo product vendor. Website is working fine but little problem with App Login due to the plugin redirection.
How do i fix or disable this login redirect.
Best Regards
- April 18, 2018 at 7:40 am #21977
Can you please define what do you mean by “App Login” ?
“How do i fix or disable this login redirect.” – where you want to redirect after login?
- April 18, 2018 at 7:50 am #21979
hoangdvo00
ParticipantThis reply has been marked as private. - April 18, 2018 at 8:32 am #21984
You may add this code to your site. It will redirect user to My Account page after login.
function wcfm_login_custom_redirect( $redirect_to, $user ) { $redirect_to = get_permalink( wc_get_page_id( 'myaccount' ) ); return $redirect_to; } add_filter( 'wcfm_login_redirect', 'wcfm_login_custom_redirect', 10, 2 );Thank You
- The topic ‘wcfm redirect issue’ is closed to new replies.
