Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › WCFM Ultimate Stops ManageWP From Working
- This topic has 9 replies, 2 voices, and was last updated 6 years, 3 months ago by
Olive&Lake.
- April 20, 2019 at 9:18 am #58714
Olive&Lake
I need to have ManageWP working on my website. I have 100+ websites which I manage.
Unfortunately, when I activate WCFM Ultimate – ManageWP disconnects and times out. As soon as I deactivate WCFM Ultimate plugin and reconnect ManageWP starts working again. Activate WCFM Ultimate and it disconnects again.
Any advice on how to fix this?
Thanks in advance.
William
- April 21, 2019 at 5:38 am #58787
- April 22, 2019 at 3:34 am #58909
Olive&Lake
There is nothing here.
- April 24, 2019 at 9:22 am #59146
MemberOK, do you have contact ManageWP yet, if they can provide any reason for this!
Between, kindly disable “Verification Module” from WCFM Admin Setting -> Modules and check once.
- April 26, 2019 at 9:13 am #59519
Olive&Lake
ParticipantI didn’t contact ManageWP because it is your plugin which breaks their plugin and not your plugin which is broken by them!!! I can contact them if you want me to. Anyway, their FAQ says if ManageWP doesn’t work when another plugin is causing it then to contact you. But I can submit a support ticket for them if you want.
However, it’s easy to replicate this issue. Did you manage to replicate it?
I disabled verification module and no change.
- April 27, 2019 at 9:12 am #59645
Well, you may share site details with us and we may debug this for you – https://wclovers.com/woocommerce-multivendor-customization/
- April 28, 2019 at 10:33 am #59745
Olive&Lake
ParticipantThis reply has been marked as private. - April 29, 2019 at 7:47 am #59841
MemberThanks for the details, we are checking this.
- May 6, 2019 at 1:41 pm #60932
Olive&Lake
ParticipantHi. Is there any update?
- May 16, 2019 at 5:26 am #62374
Olive&Lake
ParticipantI’m waiting patiently! Is there an update? It’s been 16 days since your last reply.
- The topic ‘WCFM Ultimate Stops ManageWP From Working’ is closed to new replies.
