WCFM with WC Bookings and accommodation bugs
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › WCFM with WC Bookings and accommodation bugs
Viewing 5 reply threads
    • #75809
      nict
      The WCFM interface for vendors when adding wc booking and wc accommodation products has issues when it comes to the availability settings. In wp-admin when adding a booking product the setting is named ‘Restrict selectable days’ and not ‘Restrict start days’. When adding an accommodation product it is ‘Restrict start days’ and functions differently. But in WCFM both booking and accommodation products shows ‘Restrict start days’ and so it functions differently to what it is supposed to with the different product types. It ends up restricting the wrong days in the frontend.
      The availability ‘rules’ when setting up rules also seem to behave differently, adding in some cases extra days when one restricts it show a certain date range as ‘not available’
      Then also, when adding an accommodation product from the wp-admin the ‘Calendar display mode’ setting has ‘Calendar always visible’ selected by default as it should be but in WCFM it has has ‘display calendar on click’ selected by default.
      That’s my experience so far with all the latest updates. Not sure if there are more issues with rules and restrictions etc.
    • #76199
      We will take care of this in next update.
      • #80101
        nict
        Hi Hi. I see the issues are still there with the latest updates?
        • #80445
          Do you have updated WCFM Ultimate to the latest version, 6.2.9 ?
          • #80455
            nict
            Yes the latest
    • #76372
      nict
      Great, thanks man
    • #80589
    • #112982
      SteveB
      Hi nict,
      Not sure if you still have the same issues but I’ve just checked and to confirm in the wp-admin backend, if you create a new product and select ‘Accommodation product’ instead of ‘Booking product’ then the settings mirror those in the wcfm ultimate dashboard.
      Whereas if you select the ‘Booking product’ then it is as per your post.
      I hope that helps
      Regards
      SteveB
    • #114783
      We have resolved this WCFM Ultimate latest update, please be sure you are using it’s latest version, 6.4.7
      • #114847
        nict
        • #115274
          I have already pass this message to our customization and hopefully they are already communicating with you.
  • The topic ‘WCFM with WC Bookings and accommodation bugs’ is closed to new replies.
