Multi Vendor Marketplace Plugin | WCFM Marketplace › Forums › WCFM – Ultimate › WCFMu address geocoder menu item and voucher template issue
- This topic has 7 replies, 2 voices, and was last updated 4 years, 11 months ago by WCFM Forum.
- May 13, 2019 at 5:10 pm #62096JegGuest
Voucher template selection dropdown is not visible for bookable product.
Address geocoder menu name is empty.
The orders view has a column called purchased. The item is a link leads to nowhere.
https://www.loom.com/share/257883eb5b9641c5a9b8cade52b8d781The PDF output of orders renders item columns without any separation:
Updating booking status does not refresh the order status:
https://www.loom.com/share/257883eb5b9641c5a9b8cade52b8d781Please kindly fix them at update.
Please fix them at update.
- May 16, 2019 at 9:18 am #62439WCFM ForumKeymaster
– Booking has no such option. Which voucher plugin you are using? How this field added there, is this by custom coding ?
– You have to define this name at “Geo coder” plugin’s setting panel.
– It’s for hide/show ordered items.
– Is this happen by default ? I think, NO.
- May 16, 2019 at 3:59 pm #62524ZoltanGuest
– Booking has no such option. Which voucher plugin you are using? How this field added there, is this by custom coding ?The field is rendered by your plugins. No custom tweak or code is there. I use WooCommerce PDF Product Vouchers plugin by SkyVerge.
– Yes, it happens by default. No custom tweak there.
- May 17, 2019 at 4:16 pm #62672WCFM ForumKeymaster
– We are checking this, but as I know PDF Voucher does not work for Booking type products.
- May 18, 2019 at 4:46 pm #62845ZoltanGuest
Please also check the Booking and Order status synchronization as well.
OTHER
Text editor shortcut modal window looks weird:
http://prntscr.com/nq9ey0 - May 20, 2019 at 4:18 am #62969WCFM ForumKeymaster
Well, shortcut popup should look like this – https://ibb.co/K77MmKG
It’s possibly due to your theme CSS.
Between, which theme you are using for the site ?
- May 22, 2019 at 4:07 am #63263ZoltanGuest
I’m using Flatsome 3.8.3 Theme
- May 22, 2019 at 2:15 pm #63360WCFM ForumKeymaster
Please add this CSS to your site –
.mce-window .wp-editor-help table.fixed { position: relative !important; }
- The topic ‘WCFMu address geocoder menu item and voucher template issue’ is closed to new replies.
