Flash Sale - Power Up New & Growing Businesses Upto 20% OFF on all addons.
00Day 06Hr 13Min 15Sec
WCMP Vendors list not showing
Viewing 9 reply threads
    • #116607
      andre
      Hi
      Please I hope someone can help
      I have been struggling to get a vendors list on my front page. I tried another page but with the same result, I only see the actual code and no list.
      I am using:
      WP ver 5.4
      PHP ver 7.2
      WC Frontend Manager
      Elementor
      Theme Storefront Business Version: 1.0.10 By ceylonthemes
      I have tried the following:
      [wcmp_vendorslist]
      [wcmp_vendorslist orderby=”ASC”]
      [wcmp_vendorslist orderby=”registered” order=”ASC”]
      see the home page as well as on the about us page
      I have found a sample of what it should look like here
      http://wcmpdemos.com/moumita/vendor-list/
      My site is:
      http://www.globalmerchant.co.za
      Also I would like to know if it is possible to disable “Add to my Store” on the vendors page, it allows the vendor to add other vendors products to their store.
      Thanks in advance
      Andre
    • #116822
      Which version are you using for WCFM plugin?
      Actually after WCFM 3.4.0 we have stopped the support for WCMp as it’s active growth has fallen to a great extent. Please see : https://wclovers.com/blog/were-breaking-up-with-wcmp/
    • #116855
      andre
      Hi, sorry I am using Version 6.4.7
      • #116870
        Sorry for the typo, it isn’t WCFM 3.4.0
        It is WCMp 3.4.0. after WCMp 3.4.0 we have stopped the support for WCMp.
        Which version are you using for WCMp plugin?
    • #116876
      andre
      I am using Version 3.3.7
    • #116877
      andre
      Hi, sorry problem solved, I didnt have WCMP installed only WCFM, sorry about that, however please can you help with
      Also on the product page a vendor can add products to categories, can this be disabled and let them create their own categories?
      My site is:
    • #116923
      >>Please go to WCFM Admin Setting -> Modules -> Set OFF “Single Product Multi-vendor” and “Add to Store Catalog” modules – https://ibb.co/VNCkwWN
      >>Sorry this point is not clear. Can you explain it little more with a screenshot.
    • #118876
      andre
      Sorry about the long delay, I don’t get notifications when someone responds to my post
      I am really battling to understand how categories work. When a new vendor adds a new product, which category should they use, can they add their own category, or must I create it from wp back-end?
      I have attached a pic
      Andre
    • #119020
      If the “Add Category” capability is available for vendor, then The vendors can create product categories, and other vendor vendors will be able to see these category because you cannot restrict/assign a particular category to a vendor and it will not have a particular author( as it’s possible in post ).
      And you/admin can create any product category from wp-backend, vendor can add their product in those category.
      Hope now it will be clear to you.
      • #121058
        Please update our WCFM plugins and try this code,
        add_filter( 'wcfm_is_allow_restrict_vendor_own_term', '__return_true' );
    • #119044
      andre
      Hi thanks for the response, where can I enable “Add Category”
    • #119150
      andre
      Thanks I will upgrade
      Andre
