Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › What the \"CUSTOMER\" function is for?
- This topic has 29 replies, 4 voices, and was last updated 6 years, 7 months ago by
- March 14, 2019 at 9:10 am #52561
Alex
GuestWhere I can find detailed documentation of this function?
I noticed that customers can be added only manually, that is senseless…
There is a way to add customers into this list automatically when they buy something from the vendor store? - March 14, 2019 at 9:17 am #52565
Alex
GuestAlso….a vendor can’t delete customers from the “manage customers” page!!!
Is it true?
- March 14, 2019 at 1:26 pm #52603
Alex
GuestAnyone can help me?
- March 14, 2019 at 5:27 pm #52682
Off course, those customers also listed under customers dashboard.
Vendors also allowed to delete customers, but then that customer should be added by that vendor!
Customers is like vendor’s leads.
ell, if you do not like this module then may disable from WCFM Admin Setting -> Modules -> Customer
- March 15, 2019 at 1:31 pm #52839
Alex
GuestIf I asked this question it is because they are not added automatically!
And I can’t even eliminate them if I create them!
- March 16, 2019 at 9:26 am #52946
MemberWhich multivendor you are using?
- March 17, 2019 at 7:49 am #53078
Alex
GuestI m using all your plugin.
- March 17, 2019 at 12:58 pm #53114
ing.rapparini
ParticipantFROM “MANAGE CUSTOMERS” I CAN’T DO NOTHING!
AND IF I ADD A CUSTOMER I CAN’T DELETE IT!
I NEED NEW CUSTOMERS ARE ADDED AUTOMATICALLY WHEN THEY BUY SOMETHING FROM THE STORE.PLEASE HELP ME.
- March 17, 2019 at 4:01 pm #53141
Please show me your customers dashboard view as Admin login!
- March 18, 2019 at 6:57 am #53187
Alex
GuestIS THE SAME!
Why I can’t delete customers?
I want they add to this list automatically when they buy something from the store (for any vendor of the site).
- March 18, 2019 at 11:02 pm #53368
Fany VanDaal
Participantto alexi:
but you are looking at your CUSTOMERS.
You see, you, as an administrator, are a reseller, and you look at the customers who bought you
If nobody bought you, you can’t see customers here
Customers see the vendor with whom the customer purchasedIf you want to manage all customers, then you can control them directly in wordpress-> user
now you understand? nobody bought you, so you can’t have customers here
- March 19, 2019 at 6:55 am #53420
Alex
GuestFany Van daal…WHAT ARE YOU SAYING?
How can you say that nobody bought???
I have done a lot of buy/sell from different users on my marketplace and none “customer” has been added!!!So, what is his purpose If they are not added automatically and is also impossible to delete them?
Why a vendor can create a new customer and not delete it???I want any user can see/manage his customers…like this plugin says, and this is a multivendor plugin!!!
I know I can manage all from admin!You say: “If nobody bought you, you can’t see customers here
Customers see the vendor with whom the customer purchased”…BUT THIS NOT WORKS!I hope you understand.
- March 19, 2019 at 7:30 am #53439
Fany VanDaal
Participantto Alex:
we do not understand each other.
you are the vendor Admin
You have other vendors registered, like Alpha and Beta
If the customer buys at Alpha, only Alpha sees him
If a customer buys at Beta, he only sees it as a beta
These Admins do not see these users
If the customer buys from Admin, only the Admin sees itYou have to be a Store Vendor to see your customers on the page you mentioned.
- March 19, 2019 at 8:48 am #53460
Alex
GuestI understand well!!!
I do exactly what you say!!!
And NO CUSTOMER added to that list!!!“If the customer buys at Alpha, only Alpha sees him” –> NO ALPHA DOES NOT SEE HIM!
“If a customer buys at Beta, he only sees it as a beta” –> NO BETA DOES NOT SEE HIM!
THAT’S THE POINT!
I TOLD YOU I DO A LOT OF TRY…from different user!But, why you don’t answer at the other question: why Is not possible to delete customers if I (or anu vendor) can create them?
- March 19, 2019 at 8:59 am #53461
Fany VanDaal
Participantto Alex:
Capability Settings
Are you properly turned on?
You must be logged in to view attached files. - March 19, 2019 at 9:03 am #53464
Alex
GuestA made an order
B receive the order
A pays the item
B mark the order as complete
B mark the order shipped
A mark the item as received
B must see A as customer right? –> It does NOT HAPPEN!!!
B add A as customer manually (!) –> B CAN’T delete A!!! - March 19, 2019 at 9:13 am #53470
Alex
Guestx FANY:
Ps. thanks for your patience. The problem is also there’s not good documentation on all capabilities in the website…I can’t find nothing about this function.
- March 19, 2019 at 9:14 am #53472
Alex
Guestx FANY:
- March 19, 2019 at 9:30 am #53473
Fany VanDaal
ParticipantI’m just a user, but I understand the logic of this module.
Do you have a screenshot, how did I send it?
Do you use the WOOCOMMERCE FRONTEND MANAGER – GROUP & STAFF plugin?
Do you have these rights properly enabled in groups?
- March 19, 2019 at 10:31 am #53475
Alex
GuestYes, this is a screenshot of the capabilities of a group!
But, in your website it works?
Customers are adding automatically?
You can delete them? - March 19, 2019 at 10:42 am #53477
Fany VanDaal
ParticipantWell, you’re using Groups.
Groups have superior capabilities capabilities.
If you do not have this option enabled by default, it will not work in capabilities groups even if you have it there.
Can you verify that you have this turned on by default?
(unfortunately there is a translation error, even if I have the ENG language turned on, I see the menu in my native language, so I attach notes to understand)
You must be logged in to view attached files. - March 19, 2019 at 11:29 am #53481
Alex
GuestYES ALL TURNED ON…
PLEASE ANSWER ME… in your website it works?
You can delete them? - March 19, 2019 at 11:49 am #53483
Fany VanDaal
ParticipantThis reply has been marked as private. - March 19, 2019 at 11:52 am #53485
Fany VanDaal
Participantbut you are right that the removal of the customer could be directly in the WCFM administration in order not to go into the wordpress administration.
- March 19, 2019 at 5:08 pm #53554
ing.rapparini
ParticipantI can’t see the private message!!!
:-)))) ahahaha on this website/forum I can’t also find the button to login/logout!!!
Is it possible I’m the 1st one notice this problem on “customers” function?
Is someone using this plugin FOR REAL or all are using this to have fun????
- March 19, 2019 at 5:13 pm #53557
Fany VanDaal
Participantsorry 🙂
You must be logged in to view attached files. - March 19, 2019 at 5:18 pm #53564
ing.rapparini
ParticipantOk Fany…thank you for the video…but you understans is ABSOLUTELY IMPOSSIBLE FOR ME TO ADMIT ALL VENDORS TO ADMIN!!!
THIS IS INCREDIBLE FOR ME…for a multivendor marketplace and for a not free plugin.
please WCLOVERS do a “delete button”
and made customers goes automatically on that “function”.
- March 20, 2019 at 9:20 am #53648
Memberplease WCLOVERS do a “delete button”
– We will add this in coming version!
- March 20, 2019 at 12:52 pm #53690
ing.rapparini
ParticipantOk! Great!
Please fix also to add customers automatically when they do an order!
Thanks - March 20, 2019 at 5:08 pm #53746
Memberyeah sure.
- The topic ‘What the \"CUSTOMER\" function is for?’ is closed to new replies.
