Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Where can I customize emails for after successful registration to vendors?
- This topic has 20 replies, 3 voices, and was last updated 6 years, 7 months ago by
- November 6, 2018 at 6:47 am #35908
samsun34567
Just a quick question.
As title, where can I do this?
I tried just translating it but couldn’t find the strings for
Your account already setup and ready to configure.
Kindly follow the below the link to visit your dashboard.
Dashboard: Visit now …
in all the plugins.
- November 6, 2018 at 2:39 pm #35944
For this kindly go to WCFM Admin Setting -> Membership
- November 6, 2018 at 2:57 pm #35949
samsun34567
I realized I’ve already set it up before….. but it doesn’t use the custom message. Could you kindly check this again? Thanks!
- November 6, 2018 at 3:13 pm #35957
MemberOK sure, I will take a look at it.
- November 14, 2018 at 8:45 am #36676
samsun34567
ParticipantHey guys,
Any updates on this issue? I tested again and it’s still not working~
- November 17, 2018 at 5:08 am #36890
We have also checked this and it’s working perfectly.
Under membership setting there has few notification email setting – https://ibb.co/evvb70
Which you have edited?Thank You
- December 30, 2018 at 4:45 pm #41736
samsun34567
I edited the exact same one as your screenshot.
Still getting the original default message.Is there something I’m missing?
You must be logged in to view attached files. - December 31, 2018 at 1:26 pm #41810
Jose
GuestI’m sorry if my advice is very absurd, but you made sure to record the changes? It has happened to me.
- December 31, 2018 at 4:17 pm #41828
MemberAre you using WPML?
- January 1, 2019 at 8:35 am #41870
samsun34567
ParticipantNo, I use Loco translate for translation.
- January 1, 2019 at 1:44 pm #41885
Jose
GuestPlease, see the link with documentation about where to put your language file.
https://localise.biz/wordpress/plugin/beginners
If you don’t put your file in the correct place, you will lost with every update your translation.
- January 1, 2019 at 2:17 pm #41890
samsun34567
I am aware of the file location. I don’t think this is a translation issue. The welcome email messages is customized through settings and the problem is the customized message is not showing. Also the default message is not translatable since the strings aren’t present.
I tried deleting the whole custom message and use a single word “test” instead -> same result.
- January 1, 2019 at 3:26 pm #41920
Look here – https://ibb.co/KjY5XD5
It has two separate two different setting option – Welcome and Thank You
Hopefully, you want to change message vendor see after registration. That is from “Thank You” setting.
- January 2, 2019 at 5:46 am #41972
samsun34567
No you’re mistaken. I’m not talking about the message shown on page after registration. The page contents works fine.
I’m talking about the email sent after a vendor got approved. More specifically, Membership -> “Welcome Email” tab -> Vendor Welcome Email
- January 2, 2019 at 7:44 am #41982
MemberOK, we are checking this.
- January 14, 2019 at 1:18 am #43410
samsun34567
Any update on this issue?
I thought it might be a plugin conflict and disabled mostly every plugin, still the same result 🙁
- January 14, 2019 at 3:40 pm #43486
We have tested this many times and it’s working perfectly.
On registration vendor’s are receiving this email – https://ibb.co/D5TrM4Z
- January 15, 2019 at 6:45 am #43586
samsun34567
ParticipantHmm okay, thanks for the effort.
I know it could be hard to pinpoint the problem if you can’t replicate them.
Could you answer one more question for me?
So I noticed the email I kept getting is a bit different from your screenshot.
Mine is
Subject:
[site_name] Successfully RegisteredContent:
Hi [first_name],You have successfully registered as vendor to our site.
Where as in the screenshot
Subject:
[site_name] Successfully subscribed.Content:
Hi [first_name],You have successfully registered.
{plan_details}
Dashboard: {dashboard_url}
Why is there a difference? Could it be because I haven’t set up membership plans or something along that line?
- January 15, 2019 at 6:47 am #43588
samsun34567
ParticipantCorrection: screenshot actually says “Dear [first_name]”, where as mine says “Hi [first_name]”.
- January 15, 2019 at 6:54 am #43590
samsun34567
ParticipantYeap! Solved it. Turns out I never set up a membership plan. Therefore it kept showing me that email. Set up a plan and it’s working.
- January 16, 2019 at 8:11 am #43832
MemberGreat 🙂
Well, we have changed setting banner order in last update as well.
- The topic ‘Where can I customize emails for after successful registration to vendors?’ is closed to new replies.
