Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Wild Cards for postal codes shipping zones
- This topic has 49 replies, 6 voices, and was last updated 5 years, 6 months ago by
james.bayliss.smith.
- January 6, 2020 at 2:11 pm #101096
Craig
ParticipantHi there,
At the bottom of this thread you indicated that WCFM would update code to fix the issue with wild cards. I don’t think this has happened yet because I can’t get them to work (after hours of testing and trying to figure out the issue)….my result is that this previous request has not yet been addressed in the code?Please review and advise.
You must be logged in to view attached files. - January 7, 2020 at 12:20 pm #101204
Craig
ParticipantAlso I have confirmed that the following wild cards are working and not working
V ____NOT WORKING – supposed to work of all postal codes starting with V
V9 ____NOT WORKING – supposed to work of all postal codes starting with V9
V9R ____WORKING – works for all postal codes starting with V9R
V9R,V9S,V9T ____WORKING – works for all postal codes starting with V9R,V9S,and V9T
V9R 5S5 ____WORKING – works for specific postal code V9R 5S5
V9R-V9V ____NOT WORKING – supposed to work of all postal codes starting with V9R through to a range ending with postal codes starting with V9V
(in other words all postal codes starting with V9R V9S V9T V9U V9V)
V9R…V9V ____NOT WORKING – supposed to work of all postal codes starting with V9R through to a range ending with postal codes starting with V9V
(in other words all postal codes starting with V9R V9S V9T V9U V9V)Can you please look at this and confirm what is going on. This has been an issue since Feb 2019 (When I first purchased your plugins) and I have not be able to go live because I can never get the shipping settings to work properly for Canadian postal codes.
- January 7, 2020 at 12:36 pm #101205
Craig
ParticipantALSO I can not get the second shipping zone to work. Once the setting are set for the first zone the other zones created after it do not seem to have any effect.
Please confirm that the cart is properly progressing to the next zone set up if the first zone settings do not match the customers address because for the life of me I can not get it to work.
You must be logged in to view attached files.- January 21, 2020 at 7:37 pm #103032
KeymasterHello,
Zone doesn’t work that way. When you (admin) create multiple zones, you need to make sure that each zone is different by choosing different ‘Zone regions’. Also add them in order from specific to more generic, otherwise the first zone rules will always be implied.So say, there is country1 and you want to set different shipping for 2 of its states (state1, state2), and keep a different rate for rest of the states. To achieve this, you need to create 3 zones, one for state1, one for state2, and one for country1. As rules gets applied from first to last, so the last rule (country1) will gets executed only if the address is not from state 1 or 2.
I can understand setting shipping zones are kind of tricky sometimes. Let me know if you find my explanation it helpful.
- January 14, 2020 at 11:05 am #101987
Craig
ParticipantGood day. I wanted to follow up on this to see if you were able to find the glitch of why this is happening?
1. The postal code formats
2. only the first shipping zone works. any zone created after zone one are not beening applied. - January 17, 2020 at 11:42 am #102403
Craig
ParticipantIn addition to this I have also tested with the “StoreFront” theme to rule out if my theme was the issue and I have confirmed it has not.
Can you please please look into this?
Can you confirm if the shipping methods created after the first one are taking effect with postal codes?
I really need to get this resolved….as you know shipping is a very important piece to a eCommerce.
Many thanks
You must be logged in to view attached files. - January 17, 2020 at 11:58 am #102413
Craig
Participantand finally as another test to rule out postal codes I also enabled USA states and tested that. Same result….and shipping method after the first one will NOT take effect. see attached screenshots for
Alaska state (the first shipping method) – worked!
and
Georgia state (second in line shipping method) – did not work!Attachments:
You must be logged in to view attached files. - January 17, 2020 at 12:35 pm #102432
Craig
ParticipantI need to make a correction.
Where I say “shipping method”…I mean “shipping zone” (not the shipping methods withing the zones…but the zones themselves) - January 21, 2020 at 10:18 pm #103057
Craig
ParticipantHi Sushobhan,
Thanks for your reply and explaining this further. I very much appreciate I will do some more testing but have some follow up questions.
1. Regarding wild cards
-if “V9R” works for all postal codes starting with V9R should “V” work of all postal codes starting with V and should “V9” work of all postal codes starting with V9-is there one for a “range” of codes? In the wooCommerce documents they indicate that V9R…V9V is supposed to work of all postal codes starting with V9R through to a range ending with postal codes starting with V9V (in other words all postal codes starting with V9R V9S V9T V9U V9V)
2. Regarding setting up the tables as an ADMIN. See the screenshot below.
I have created 10 zones with each region stated as “Canada” (which sounds like the problem as you described above). My intention was to allow the vendors flexibility in adding the “provinces” if they choose when they set up their shipping methods in each store.
What is the best way to do that?
Vendor #1 wants to have shipping rates for “just canada” (so they use Zone one as Canada” in their shop settings)
Vendor #2 wants different rates for each province (so they use all 10 zones and have a different province listed for each in their shop settings)
Vendor #3 want to have shipping costs for his city, rest of province, and rest of Canada (so they use 3 zones, one with postal codes, one with British Columbia, and one with Canada).Is there away to set this up in Admin panel to allow this flexibility between vendors and their shipping methods>?
You must be logged in to view attached files. - January 22, 2020 at 2:21 am #103089
aemr45
ParticipantHi Craig,
Please let me jump in, the only way I have found is to order this zones, first the one with postal codes, then the one with province and then the country.
I also need that vendors be able to determine specific shipping prices for local shipping and that customers can choose local pick up only if they are in the same city (postal code range) as the vendor.
The problem here is that for this to work, the seller needs to order the postal codes of his city to the top.
If you as admin set up zones of different cities (postal codes) and put them on top of province, the vendor would have to add shipping methods to each city…
I’m looking to a different approach, Plugin Hive has some plugins compatible with wcfm marketplace, and with one of their plugins, table rate shipping pro, you can set different shipping rates depending on city name, but the thing here is that we need that the city in the rule table get the city name from the vendor.
- January 22, 2020 at 4:58 am #103109
Craig
Participantaemr45 thanks for adding your info. This is very informative and rather great sanity check as I have been pulling my hair out trying to get these shipping settings to work.
…and then feeling defeated thinking “If I can figure this out how can I expect a vendor?”I did not think that the shipping requirements for my marketplace requirements were overly in that vendors need the ability to identify their own zones/shipping methods because every business is different. Some will sell right across Canada some will only sell within city limits etc.
It sounds like an additional plugin may be needed to do this and more research is needed. The Plugin Hive is one that I will look into as well.
Please let me know if you find something and I will certainly do the same.
Again thanks so much for adding your information here.
- January 22, 2020 at 5:09 am #103111
Craig
ParticipantThis was the marketplace plugin I had used previously and their flat rate shipping setup was pretty flexible for vendors to create their own zones/tables as many as they needed in each shop
https://docs.wcvendors.com/knowledge-base/wc-vendors-pro-shipping-system/Attachments:
You must be logged in to view attached files. - January 23, 2020 at 1:17 pm #103371
Craig
ParticipantI have still failed.
I have tried once again with these shipping zones can can not get them to work for postal codes. This as been a frustrating many months trying to sort this out!
“the only way I have found is to order this zones, first the one with postal codes, then the one with province and then the country”.
I did this set up and still no luck. only the FIRST shipping table is being applied.
WC Lovers please help and confirm if you can get these shipping setting to apply for Canada and postal codes.
Please show me how to make the following work
Shipping to any postal code V9R = $10 (Works as zone 1)
Shipping to rest of British Columbia = $20 (won’t work as zone 2)
Shipping to all of Alberta + $30.00 (Wont work as Zone 3)Attachments:
You must be logged in to view attached files. - January 23, 2020 at 1:29 pm #103379
Craig
ParticipantHere is a possible bug.
I turned on the WooCommerce -> System status -> Tools and checked “Shipping Debug Mode” Checkbox
and the message being displayed No matter what address I enter keeps saying “Customer matched zone “Local Shipping Zone” EVEN when it SHOULD match Zone 2 or Zone 3.
WC Lovers please help.
You must be logged in to view attached files. - January 23, 2020 at 1:30 pm #103381
Craig
Participantfor some reason the system won’t consider the other zones.
- January 23, 2020 at 3:24 pm #103399
KeymasterHello,
I have tested and it is working as expected. When I recheck your snapshots, I found a conflict between the attached two. In admin screen the Local Shipping Zone shows Zone as Canada, but in vendor screen it is showing as ‘Everywhere’.The following is the settings I’m using-
1. Create 3 Zones from admin side (WooCommerce >> Settings >> Shipping)
2 a. Zone 1 – Zone name – Local Shipping Zone, Zone regions – Canada or British Columbia
b. Click on Limit to specific ZIP/postcodes and enter V9R*
3. Zone 2 – Zone name – BC Shipping Zone 2, Zone regions – British Columbia, Canada
4. Zone 3 – Zone name – Alberta Shipping Zone 3, Zone regions – Alberta, CanadaAttachments:
You must be logged in to view attached files. - January 23, 2020 at 3:34 pm #103402
- January 23, 2020 at 10:04 pm #103466
Craig
Thanks for responding. I have tried with every way on the settings. I was screen shooting them all but must have attached the wrong one.
Regarding the postal code setting in the ADMIN side would not work for a marketplace. I was expecting that each vendor can limit their postal codes from their vendor dashboard settings?
Is that not the case?
So what I would expect is:
2 a. Zone 1 – Zone name – Local Shipping Zone, Zone regions – Canada (Not British Columbia)
Then the vendor would add the Limit to specific ZIP/postcodes and enter V9R (not * as that wild card does not works from the WCMF dashboard) from their shop dashboard settings
4. Zone 3 – Zone name – Alberta Shipping Zone 3, Zone regions – Alberta, Canada(and I would add a zone for each province)
would the above work?
- January 26, 2020 at 12:00 am #103863
Craig
ParticipantSushobhan,
I set my shipping zones just as you described above
T
4. Zone 3 – Zone name – Alberta Shipping Zone 3, Zone regions – Alberta, CanadaAND it works too!!!
BUT my question is….setting the postal code in ADMIN side won’t make sense for other vendors. how do we let vendors put their own postal code limits.
That is what I have been trying to figure out.
When I set the admin setting this way (see below)…Zone 2 or Zone 3 are never applied. It looks like basically when I try to restrict the “local zone” (First zone) from the VENDOR settings the shipping zones don’t work correctly.
4. Zone 3 – Zone name – Alberta Shipping Zone 3, Zone regions – Alberta, CanadaYour thoughts?
You must be logged in to view attached files. - January 26, 2020 at 11:33 pm #104041
Craig
ParticipantSushobhan – I guess what I was expecting is that the vendor would have the ability to add the postal code limitation in their zone settings rather than on the admin side.
Adding the limitation on the admin side would apply to every vendor which is not the case on a marketplace website. Each vendor will have different postal codes to enter based on their location.
My understanding (based on WooCommrce documentation) is that The first zone being that zone where they can enter in the postal code limits which is typically where they would enter in any kind of local shipping options.
Can you please confirm the following:
Is my assumption above correct?
Will WC lovers update their code to allow this?This is a critical piece to my marketplace to allow vendors to define there postal code limits.
Thanks for your attention to this.
- January 27, 2020 at 7:09 pm #104209
When you setup zones in this order – Canada, British Columbia, Alberta, then there is no way your zone 2 or 3 will ever gets applied. As I mentioned before, the zones are matched from top to bottom. So for any location in Canada, the first rule is a match and thus rule 2 or 3 will never get a chance even if people put their Province as British Columbia or Alberta.
This restriction is coming from WooCommerce. It only checks from top to bottom for a match and if you create multiple zones with same region, still it will only apply the first matched zone rule.
I can think of another approach, see if that suits your purpose. First create different zones, one for each province. Also a last zone with Canada set as region. Now what your vendors can do, they can set shipping charges to all other province apart from their own and then they can use the last zone (Canada) along with the postcode restriction to offer Local shipping. - January 27, 2020 at 9:22 pm #104245
Sorry, my last suggestion will not work in your case. When you create zone against each province then also WooCommerce will select the first zone that matched the buyers province. And hence the last rule i.e. Canada will never gonna applied. Sorry but at this moment I don’t have a solution for your case. I’ll try few more coding tweaks and let you know if got any success. On a different note, your request for support of postcode range is accepted by our dev team, it will be added to our future release. - January 27, 2020 at 10:04 pm #104258
Craig
I very much appreciate your attention to this.
In my mind I’m thinking it is a marketplace coding issue because basically all I’m expecting is that the vendor shipping settings to respond the same way as the admin settings you previously demonstrated as working in your Jan 23 post above.
(checks from top to bottom for a match and if you create multiple zones with same region, still it will only apply the first matched zone rule)This was your Jan 23 zone settings:
4. Zone 3 – Zone name – Alberta Shipping Zone 3, Zone regions – Alberta, CanadaSO when the ADMIN settings are set as above the shipping settings worked exactly as I have been trying to do.
Zone 1 (Canada) worked when a V9R postal code is used
Zone 2 (British Columbia) worked any other British Columbia address was used
Zone 3 (Alberta) worked any Albert address was usedSO this also means that with the above zone structure WooCommerce is working as expected
“checks from top to bottom for a match and if you create multiple zones with same region, still it will only apply the first matched zone rule.”The only thing I’m looking for (that I think the marketplace plugin needs to do) is instead of the ADMIN doing:
b. Click on Limit to specific ZIP/postcodes and enter V9R* (in the first zone)
that the vendor should be able to Click on Limit to specific ZIP/postcodes and enter V9R* in THEIR zone settings.And wooCommerce should still function the same
“checks from top to bottom for a match and if you create multiple zones with same region, still it will only apply the first matched zone rule.”Again thanks you for your time and attention to to this.
- January 30, 2020 at 1:27 pm #104648
Craig
I wanted to follow up on this to confirm the issue and if WC Lovers will be able to rectify.
My marketplace is essentially broken without this functionality to mirror the wooCommerce shipping zones (but have the vendor enter the limiting postal codes).
Craig - January 30, 2020 at 5:36 pm #104680
aemr45
I see Sushobhan commented:
That’s really good news.
In the mean while you can use Storepep, I get to accomplished what I needed with this plugin!! The downside is that you as admin need to add all postal code regions and rules, but at least it works. Pluginhive is a really good plugin and have a by city name solution but is not ready for multivendor yet. That’s why I chose the Storepep plugin.
In my case, I will add all Cities (postal code ranges) of my vendors. First of all I will ask my vendors to tell me their shipping needs, for example, local shipping flat rate, local pick up available or not, and especial flat rates for cities near by. Then I will add them to specific rules. Vendors can also have their own carrier account and have realtime shipping costs of DHL, UPS, FEDEX, Canada Post and others, and again vendors need to give you the admin this information so you can configure it in the admin account, but this way you can control if they use their carrier account or yours.
I hope this solution works for you as well as for me.
- January 30, 2020 at 9:42 pm #104725
Craig
ParticipantHi aemr45,
Thanks for taking the time to add your suggestion. I’m definitely going to check out Storeprp! as an enhancement to shipping.
Adding all the regions sound like a rather monumental task…but hey if that is what I need to do…
I love the option to real time shipping costs.I have a couple of questions:
1. For the multi-vendor features they indicate a prerequisite that “Dokan Multi vendor plugin is already installed on your WooCommerce Store” – is this true or are you using only the WC lovers plugins? (I don’t use that plugin currently).
2. How may vendors do you plan on accommodating? My marketplace is designed to accommodate 1000’s of vendors (local small businesses similar to ETSY). The task you described “I will ask my vendors to tell me their shipping needs, for example, local shipping flat rate, local pick up available or not, and especial flat rates for cities near by. Then I will add them to specific rules.” sounds like the set up for each vendor will take some time and attention – When you are adding those shipping needs for each vendor has it been onerous?
3. The Storeprp plans are based on the number of ordered full fulled. Do you know if orders of Virtual products not shipped (or pick up in store) attribute to that plan threshold?
Again thanks for your advice (although I really hope WC lovers can update their shipping integration as well)
- January 30, 2020 at 10:30 pm #104734
aemr45
Well, you can ask all technical questions to Storepep support, let me answer you with my very short experience with the plugin so far:
1.- Store Pep is fully compatible with WC Lovers – WCFM Marketplace, you can read it in this link
2.- You are right, I would like the process to be much easier, but it is what there is so far, I have not found a better solution.
3.- That’s a really good question, I wish to believe that only automatic transactions send to carriers count, not virtual products etc. but this is worth asking directly to storepep support.
Me too, we need to wait and see what solution they offer us, and hope is a better approach.
- February 24, 2020 at 12:19 am #108403
Craig
Participantaemr45 – The most recent update to the plugin has added the Postal Code Range fix and it seems to be working well. I also have word back (through email support) that the shipping table structure will be fixed soon too (I’m just not sure when).
Sushobhan – thank you so much for your attention to my initial inquiry and then for having this Postal Code Range bug fixed! It is a big relief.
Are you able to see what the time line might be on the support ticket “Shipping zones not working with CANADA – #48647”Attachments:
You must be logged in to view attached files. - February 25, 2020 at 5:53 pm #108744
KeymasterHello Craig,
We are planning to add more muscle to our country based shipping module. As of now one can add different states and assign a shipping price for it.
In our future release, we will introduce postcode (multiple) under states. So say under “British Columbia” you can create multiple postcode based rules and set up different shipping price for each postcode region. I think this will resolve what you want to achieve via “Zone based” shipping.
Thanks! - March 4, 2020 at 12:06 pm #109827
Craig
Do you have any timeline on when this enhancement would be released?
I’m very excited (and relived) to see this happening…thanks so much for keeping this moving forward.
- March 4, 2020 at 2:50 pm #109916
KeymasterHello,
We are in final phase of implementing this feature. Hopefully within this month you can expect this update.
Thanks! - March 5, 2020 at 5:04 am #110046
Craig
ParticipantThis is excellent news!
Is there any sort of published road map or blog that we can keep an eye on updates as they happen?Craig
- March 5, 2020 at 12:56 pm #110067
KeymasterHello,
We have plan for something like this. But as of now, there is none 🙁
Thanks! - March 20, 2020 at 6:30 am #112343
Craig
Do you know if this shipping zone feature has been implemented in the update yet?
Craig - March 23, 2020 at 6:07 pm #112809
KeymasterHi Craig,
Not yet. Our latest release v3.3.6 added compatibility with WooCommerce 4.0
Will keep you posted when it’s done.
Thanks! - March 25, 2020 at 12:53 am #113000
Craig
ParticipantThanks for the update Sushobhan,
WooCommerce 4 is certainly a biggie!
Hopefully this will shipping zone issue will be resolved soon as our vendors are in need of this limitation being resolved.
I appreciate all the efforts of you and the WC Lovers team.
Craig - April 4, 2020 at 2:27 am #115183
Craig
I’m just check in on this shipping fix.
With the social distancing here in Canada eCommerce has become a reality for many businesses but we are not able to offer them a shipping solution.Any update on this?
Many thanks
Craig - April 6, 2020 at 12:36 am #115729
aemr45
In the meanwhile you should really try StorePep plugin, it has really worked for me. I know its really difficult to manage shipping rules for each store but my marketplace has less than 20 stores now so I can manage it for now.
Regards
- April 6, 2020 at 2:07 pm #115861
KeymasterHi Craig,
I got a confirmation from our dev team that, postcode support in Country based shipping will be available in our next updated.
Thanks for your patience.
Regards - April 6, 2020 at 10:56 pm #116032
Craig
Participantoh this will be awesome! thanks for the update and thanks for all the continued development of your plugins!
- April 25, 2020 at 11:02 pm #122994
Craig
Do you have an update on this? I just updated the plugins but the shipping zones are still not working. Once the first zone is matched no others will apply even if I change the customer address.
aemr45 thanks for your plugin suggestion as well….my problem is that I can’t manage the shipping rules for each store….we have 77 stores and growing.
- May 4, 2020 at 11:10 pm #126630
Craig
ParticipantDo you know if this update is still under development?
- May 5, 2020 at 3:01 pm #126923
KeymasterHi Craig,
Sorry it’s not ready yet. As you might be aware, we have launched Distance rate shipping option a few days ago.
I’m feeling really bad for this delay. I’ll try to escalate this feature development.
Thank You! - May 13, 2020 at 7:24 am #130276
Craig
Thanks for the update. Please keep the pressure on as this shipping issue has really inhibited my vendors from selling to customers outside the first zone.
Are you able to get a new ETA?
Many many many thanks
- May 23, 2020 at 10:31 pm #134552
KeymasterHi Craig,
I have tested the following code and found, it works with Zone Shipping the way you intended. This means it will overcome the limitation of always returning the first zone as per your zone set up. Could you please try the following snippet for your zone shipping-add_filter('woocommerce_get_zone_criteria', function( $criteria, $package, $postcode_locations ) { global $wpdb; if ( empty( $package['vendor_id'] ) ) return $criteria; $vendor_postcode_locations = $wpdb->get_results( "SELECT zone_id, location_code FROM {$wpdb->prefix}wcfm_marketplace_shipping_zone_locations WHERE location_type = 'postcode' AND vendor_id = " . absint( $package['vendor_id'] ) . ";" ); if ( ! $vendor_postcode_locations ) return $criteria; $country = strtoupper( wc_clean( $package['destination']['country'] ) ); $postcode = wc_normalize_postcode( wc_clean( $package['destination']['postcode'] ) ); $zone_ids_with_postcode_rules = array_map( 'absint', wp_list_pluck( $vendor_postcode_locations, 'zone_id' ) ); $matches = wc_postcode_location_matcher( $postcode, $vendor_postcode_locations, 'zone_id', 'location_code', $country ); $do_not_match = array_unique( array_diff( $zone_ids_with_postcode_rules, array_keys( $matches ) ) ); if ( ! empty( $do_not_match ) ) { foreach ($criteria as $key => $val) { if(strpos($val,'AND zones.zone_id NOT IN (') !== false) { $start = strpos($val, '('); $end = strpos($val, ')', $start + 1); $prev_do_not_match = explode(',', substr($val, $start + 1, $end -$start - 1)); $do_not_match = array_unique(array_merge($prev_do_not_match, $do_not_match)); $criteria[$key] = 'AND zones.zone_id NOT IN (' . implode( ',', $do_not_match ) . ')'; break; } } } return $criteria; }, 10, 3);Add this code to your child theme’s functions.php
In case you do not have a child theme then add code using this plugin – https://wordpress.org/plugins/code-snippets/Let me know how this goes.
Thanks! - June 22, 2020 at 12:54 am #143075
mick2
Participant@sushobhan
Hi sushobhan, I have exactly the same problem as Craig with the zone shipping.I’ve got vendors that do free shipping in their city but not their state.
I’ve tested your code in every way but it doesn’t work. Are you still planning to include it in a future update?I really need this feature to work. Without it, my company can’t get started.
I’m willing to pay for custom code.
thank you very much
Mick
- June 22, 2020 at 10:53 pm #143289
Craig
Participant@mick2 – I have not yet implemented the code snippet that @Sushobhan has provided above to know if it works for me or not. BUT I agree this code/functionality should part of the base code as it seems to be the foundation to proper eCommerce to have shipping zones that work.
- July 18, 2020 at 4:23 am #151636
switch_900
ParticipantTo make a local shipping region in WooCommerce that covers just the lower mainland of Vancouver use the following
Under shipping zones create a region called Lower Mainland
Under Zone Regions select British Columbia
Specify by postal codes and use the following wildcard entries
V3*
V4*
V5*
V6*
V7*Those 5 wildcard entries cover most of the region unless you want to go out past Langley or to Mission
Create a shipping method for that region (ie. Free local shipping etc.)
- July 20, 2020 at 3:44 pm #152790
james.bayliss.smith
ParticipantHi all, I’ve just came across this thread and though someone might be able to help my similar problem.
I have set up shipping codes to give free delivery in Bristol (UK). I want to deliver to postcodes BS1-9 for free. So I set it all up fine but I’ve just realised that if someone puts in the post code BS26 for example, woocommerce recognises it as BS2 and gives that customer free shipping. So I need to EXCLUDE BS 10-49 anyone know how to do this?
James
