Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › WooDiscuz integration
- This topic has 3 replies, 2 voices, and was last updated 5 years, 10 months ago by
- October 21, 2019 at 5:53 pm #88069
laken
I need the opportunity for the buyer to comment on products. The plugin Woodiscuz can do that. Unfortunately, the comments can only be approved by the admin. The vendors do not see these comments or are not notified about new comments.
In addition, the comment function should only be selectable on specific products or product categories.Do you see this one way to integrate WooDiscuz or another plugin?
The reason is, customers should see who has entered into a list. Because the product only has a certain number of parts. The customers should show their interest with an entry.Thank you!
- October 21, 2019 at 7:11 pm #88081
laken
ParticipantI just had the idea to regulate the visibility for certain products and categories via the plugin “WooCommerce Tab Manager”. I installed it…it is active and visible in the backend, but not in the WCFM. How can the vendors configure this? Do I need ultimate for that?
- October 21, 2019 at 7:39 pm #88092
laken
ParticipantOk, i did the upgrade to ultimate and now i see the tabs. Works fine 🙂
The only thing is now that the vendors are not informed if a product was commented. Do you see another solution for me?
- October 23, 2019 at 12:01 pm #88455
– Please check at WCFM Admin Setting -> Review Setting -> Is this option enabled? https://ibb.co/tBsMPrX
- The topic ‘WooDiscuz integration’ is closed to new replies.
