Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Wrong fee display in refunded order line
- This topic has 11 replies, 2 voices, and was last updated 6 years, 1 month ago by
- August 21, 2019 at 6:23 pm #77666
CommunityCorals
For refunded items the calculation of fee is wrong. See screenshot. I guess you need to deduct refunded amount from fee amount.
BR
DominiqueAttachments:
You must be logged in to view attached files. - August 23, 2019 at 6:34 am #77952
Is this refund created using WCFM refund request process or just directly from wp-admin -> orders ?
Well, if refund does not go thought refund request process then commission will not updated!
Check this – https://www.loom.com/share/7c0239b01e5345ceb3bc5317e7e3fbb9
- August 25, 2019 at 8:54 am #78249
CommunityCorals
ParticipantOk, got it. Could you please follow up on this https://wclovers.com/forums/topic/bug-in-order-listing/#post-75872 in order to make refund request workiong again?
Dominique - August 25, 2019 at 6:44 pm #78298
CommunityCorals
ParticipantHi just double checked. Commission is updated when refund is reffering to line item. Issue here was that refund was not refering to line item.
- August 29, 2019 at 3:07 pm #78983
If commission already withdrawal-ed for an item then “Refund Request” not allow for vendors.
If you refund that from wp-admin -> orders then will not effect on vendor’s order and withdrawal.
- August 29, 2019 at 4:25 pm #79008
CommunityCorals
ParticipantIf you refund that from wp-admin -> orders then will not effect on vendor’s order and withdrawal.
That is not correct. If I refund from wp-admmin the commission amount is reduced by refunded amount. So for complete refund the withdrawal amount will be 0.
- September 2, 2019 at 4:39 am #79531
– Yes, this happen. But only if “Withdrawal” not yet processed for this order. If vendor already withdraw this order commission and then we change withdrawal amount it will cause damage reporting.
- September 2, 2019 at 8:13 pm #79709
CommunityCorals
ParticipantOk, I am afraid this happened – I also have negative admin amounts and white templates under dashboard stats. You think this can be related to this?
- September 2, 2019 at 8:16 pm #79711
CommunityCorals
ParticipantSorry I missed to post the screenshot. Also I have to mention that this issue is for every vendor not just for the one where the refund might happen the wrong way.
You must be logged in to view attached files. - September 4, 2019 at 8:13 am #79948
NO, off course not.
DO you have any plan to update your site’s plugins?
I think, update will resolve this for you.
- September 4, 2019 at 3:16 pm #80069
CommunityCorals
ParticipantMost of my plugins are up to date. Just updated WCFM Plugins but issue still exists.
Any specific Plugin you think is causing this issue?
- September 7, 2019 at 11:00 am #80570
MemberJust checked, it’s not loading perfectly – https://ibb.co/J2fKsSW
