Forum Replies Created
bruce.rockow
ParticipantYes, all of my products are affiliate links. I do not have any products purchased on my site.
bruce.rockow
I see what I did wrong. I copied your code from my email and did not realize that Gmail did not display it the same as what was in the support thread. My fault for not seeing the difference. You are very much correct. Your code works fine and now the user is automatically logged off during the Membership Registration process.
I do have one last question. Will this possibly be a part of any upcoming release? I am curious to know if this is something you are considering even though it is no fault of WCFM.Thank you again for your patience and understanding.
bruce.rockow
Thank You for your explanation regarding this being WP default behavior. That being the case I understand there not being an easy solution.
I added the code you suggested to my child theme functions.php file. Unfortunately I received a fatal error and my site would not come up. There seems to be a syntax error that I cannot seem figure out. Could you check the code and see if maybe there may be an error? I am not proficient in php.
Thanks again for your support.bruce.rockow
ParticipantThis reply has been marked as private.bruce.rockow
I am wondering if there has been any progress on my issue? I have provided all credentials to my site in my last post. I did mark my last 2 posts private and not sure if you received them.
Thank you kindly
bruce.rockow
ParticipantIn addition, I have tried checking the email verification code box where the vendor gets an email and they have to fill in the code number. The process works the same way. The vendor is immediately logged in as a subscriber. That is not the way I need it to work.
