Forum Replies Created
dan.benson
ParticipantThis reply has been marked as private.dan.benson
Participant2. We would like an auto relist checkbox. When the deal ends the product timer will automatically republish, rather than having to manually relist.
dan.benson
ParticipantI’ve had to split my message over three parts as it wouldn’t send otherwise..
We would like to change the input fields a little:
1. Swap the date pickers for a single numeric input. When the product is published the ‘start date’ would be set to ‘now’ and the end date would be set to the number of hours after the ‘now’ date (set by the new numeric input).
dan.benson
ParticipantThanks for your reply. I’ve tried using the form on the page you sent but I keep getting an error.
We’re looking for a quote for the following work:
We’re using the below group buying plugin alongside WCFM. We understand that we can purchase an add-on for WCFM which will allow this product type to show within the vendor dashboard.
