wcfm-santa
-365Day -2Hr -41Min -25Sec
wcfm-santa
WC Lovers
WooCommerce Frontend Manager - Multivendor marketplace vendor dashboard
Forum Replies Created
Viewing 1 post (of 1 total)
  • in reply to: Vendor Page missing Header & Footer #88546
    Thanks for that.
    The support for Theme X / Pro at Themeco informed me that there is a conflict between the Theme and WCFM. They are not able to help me at this point but have added it to their issue tracker so this will be queued for investigation by their development team. See below their conclusion.
    The filter cs_match_header_assignment is not being called on that page. And the reason is probably the templates your plugin use. Example, I checked that page and it uses a different template codes.
    And that filter will only activate where it’s called, in theme’s template.
    I’ve done the following tests:
    Assigned one of your headers as Global and the Global Header won’t show up on the vendor page.
    Switched the header to the Original/Classic Header and still no dice
    Switched to the parent theme and issue persists
    The vendor page shows the header of the default WordPress TwentyNineteen theme.
    The Global Header or even the Classic/Original Header will need to be displayed first before using the cs_match_header_assignment filter as that’s just to override the header assignment.
    Theme Pro is a popular theme and I hope that you are able to provide some solution or assistance with this.
    Thanks in advance!
