Forum Replies Created
john.boase
ParticipantThank you but that doesn’t work either so in Admin I unchecked ‘Store Shipping’ to disable vendor wise store shipping options to see what happens and the vendor is still showing the same shipping options when adding a product (see attachment Vendor-Settings.jpg) although the option for the vendor to set their own shipping from their settings has disappeared???
Do you know if Woocommerce Simple Auctions overrides WCFM shipping?
You must be logged in to view attached files.john.boase
ParticipantThanks for the quick reply and I will check out Woocomerce per product shipping plugin but I assumed that was built in as all vendors will want to have different shipping for their different product?
The real issue is that the vendors shipping options do not change no matter what shipping method I choose in Admin or the Vendors global shipping options.
