Forum Replies Created
- June 9, 2020 at 3:19 pm in reply to: Commision Percentage of the transaction/sale value + a fixed amount per unit #139871
SteveB
Okay, understand that you wish to set the commission by ‘Admin’ but want the reports displayed as though ‘Vendor’ commission has been set.
Hopefully one of the wcfm team can provide a filter to enable this.
Regards
SteveBJune 8, 2020 at 7:54 pm in reply to: Commision Percentage of the transaction/sale value + a fixed amount per unit #139632SteveB
If I’ve understood your requirements then you could try:-
1. Login as Admin
2. Select ‘Marketplace’
3. Select ‘Commission Settings’
4. Select ‘Commission for’ = Admin
5. Select ‘Commission Mode’ = By Product price
6. Then select ‘Commission Type’ = Percentage + Fixed
7. Then enter the % and fixed commission in the relevant fields.Hope this helps
Regards
SteveBSteveB
Good News.
Further testing in sandbox mode I switched from paypal sandbox to stripe in Test Mode and now working so I suspect there is a problem testing the Refund process using sandbox.
Regards
SteveBSteveB
ParticipantHi bp,
I’m getting the same error and wanted to check if you managed to resolve and if so if you could detail.
Regards
SteveBSteveB
ParticipantHi nict,
Not sure if you still have the same issues but I’ve just checked and to confirm in the wp-admin backend, if you create a new product and select ‘Accommodation product’ instead of ‘Booking product’ then the settings mirror those in the wcfm ultimate dashboard.
Whereas if you select the ‘Booking product’ then it is as per your post.I hope that helps
Regards
SteveBJanuary 20, 2020 at 4:00 pm in reply to: RnB Rental and Booking plugin – missing funcionalities #102845SteveB
I wish to use the RnB Booking plugin but also require some of the functions that aemr45 has requested.
Just checking if these will be made available in your next Ultimate plugin release?I hope you don’t mind me also using this topic to as a further question relating to RnB Booking as for some reason I cannot create a new topic.
Anyone out there using the RnB Booking plugin Add-On – Seasonal Pricing: https://codecanyon.net/item/rnb-seasonal-pricing-addon/25037993
Regards
SteveBSteveB
You may wish to consider hiding Product Types in Woocommerce so only the custom product type ‘Rental’ is visible.
Hope this helps
Regards
SteveB - AuthorPosts
