Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › About product custom select field
- This topic has 5 replies, 2 voices, and was last updated 8 years, 2 months ago by
- July 30, 2018 at 1:32 pm #27253
MOHO
ParticipantIf i use chinese option “免稅|含稅” (no use english)
1. When user choose “免稅”, then “_cw_ei_tax_type” meta save “tax_free”.
2. When user choose “含稅”, then “_cw_ei_tax_type” meta save “taxable”.Now i can’t make it…
How could i do it?
By Moho
You must be logged in to view attached files. - July 30, 2018 at 4:48 pm #27259
Well, WCfM custom fields select option does support such option.
You may use this – https://wordpress.org/plugins/types/
It supports option key value separately.
So, you may set English key and Chinese value easily.
- July 31, 2018 at 1:54 am #27289
- July 31, 2018 at 6:51 am #27315
If you create custom field using Toolset then those will be directly available at WCfM Product Manager.
Kindly check this – https://wclovers.com/knowledgebase/wcfm-toolset-types/Yeah right, as I already told you there is custom field option which works for variations!
- August 2, 2018 at 4:23 am #27456
MOHO
Participantyeah i research it, and work now, thanks.
please close this discuss. - August 4, 2018 at 5:05 am #27561
MemberOK, thank you 🙂
- The topic ‘About product custom select field’ is closed to new replies.
