Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Add Product Shortcode
- This topic has 11 replies, 3 voices, and was last updated 7 years, 5 months ago by
Bingal.
- March 10, 2018 at 5:40 pm #20088
info31
I am using a listing directory theme. Users are able to create listings and to attach 1 or more products to each listing.
I am working to create a streamlined workflow for creating Listings and attaching the Products to listings.
At the moment, my workflow is very clumsy and takes too many steps for users.
(e.g Paid Listing -> Add listing -> Create Product -> Open listing and add Products).I would like to add the “ADD PRODUCT” form to the “ADD LISTING” page. Is there a short-code for the “ADD PRODUCT” form that I can use?
If this is not possible, is it possible to add a custom link at the bottom of the “ADD PRODUCT” page (that links to the ADD LISTING page)?
- March 10, 2018 at 7:00 pm #20096
Bingal
This is one of WCFM Ultimate exclusive feature.
Kindly check this – https://wclovers.com/knowledgebase/wcfm-product-listings/
- March 11, 2018 at 4:16 am #20130
info31
If you remember, I purchased the “Products for WP Job Manager” plugin previous to achieve that.
However, it didn’t work and both WCLovers team couldn’t figure it out and Astoundify (Products for WP Job Manager) provided a refund. I’m currently using MyListing theme + WC Vendor Pro + WCFM. All sides were saying that the other parties plugin was to blame.
The product field did not show up on the Add Listing page, as your demo in the link shows.
Is there something that I’m missing?
(Note: I am currently a paid WCFM Ultimate subscriber).
- March 11, 2018 at 10:12 pm #20171
Bingal
“If you remember, I purchased the “Products for WP Job Manager” plugin previous to achieve that.” – I can’t recall this, where you have communicate with us regarding thins?
“info@golivmo.com” – is this you any chance?
- March 12, 2018 at 1:46 am #20176
info31
ParticipantHi Bingal,
Yes. info@golivmo.com is us.
We’ve purchased the “Products for WP Job Manager” previously to be used with WCFM / WC Vendor Pro, but it didn’t work, unfortunately. After the installation of the plugin, the product field did not show up on the “Add Listing” form.
Here’s the Add Listing form generated by MyListing theme/WCVendor Pro.
https://imgur.com/a/2XpwLI’m still struggling to figure out a solution without having the user jump through multiple steps to Add Listing -> Add Product -> Re-Open Listing to Add Product. Users also have to jump between 2 dashboards (MyListing Theme Dashboard to Add Listing and WCFM to Add Product).
Any suggestions on how I can use WCFM exclusively?
- March 12, 2018 at 4:22 am #20187
Bingal
Thanks for clarification, I was getting confused as you are communicating from three channels 🙂
I know your this issue and it’s totally from MyListings theme.
WC Vendors Pro has no support for Listings.
I have already told you, I am checking this and compatible WCFM this feature with My Listings theme as well.
Please give me a bit time.
- March 12, 2018 at 8:59 am #20200
Kevin
GuestThanks Bingal.
Yes, I got confused with the multiple channels as well. Apologies , I was trying to find a solution and was trying all avenues.
Thank you once again. Thanks for checking the compatibility as well.
- March 12, 2018 at 7:43 pm #20237
Gordon
GuestWaiting for an answer to MyListings Theme compatibility issue with the add/edit listings UI.
- March 13, 2018 at 8:58 am #20250
Bingal
KeymasterWe are working on this.
Please keep a bit patience.
thanks for your cooperation.
- March 18, 2018 at 7:49 pm #20506
Bingal
We have already implemented this and updated WCFM U installed at your site.
Kindly check and know me is this working as per requirement of not!
Thanks for your patience.
- March 19, 2018 at 4:38 pm #20593
Kevin
GuestThank you Bingal! That works fantastic!!
- March 19, 2018 at 7:45 pm #20599
Bingal
KeymasterAwesome awesome … finally it’s our super success 🙂
Thanks for your cooperation all the way and keep trust on us.
Really pleasure to have user like you 🙂
- The topic ‘Add Product Shortcode’ is closed to new replies.
