Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Ajax error
- This topic has 11 replies, 2 voices, and was last updated 6 years, 1 month ago by
- March 25, 2019 at 10:58 am #54429
JulienCKJM
ParticipantHello, I’m getting the same issue as the second question in this ticket https://wclovers.com/forums/topic/manual-ordering-with-multiple-item-and-error-to-load-ajax-vendor-table/
I’m getting the message DataTables warning: table id=wcfm-products – Ajax error. For more information about this error, please see http://datatables.net/tn/7 (the portion “table id=wcfm-…” varies with respect to the module that I try to oppen. It may be the products list, the vendors list, the commands list, the support list,…) - March 25, 2019 at 11:08 am #54431
JulienCKJM
ParticipantCould anyone tell how to fix this issue please?
- March 26, 2019 at 3:07 pm #54575
And know use the exact error.
Also check at Google Chrome browser console, if error is there or not!
- March 26, 2019 at 3:25 pm #54577
JulienCKJM
ParticipantFatal errors are being generated in woocommerce status indeed
- March 26, 2019 at 3:33 pm #54580
JulienCKJM
ParticipantThis reply has been marked as private. - March 26, 2019 at 3:55 pm #54590
JulienCKJM
Participantbtw, my wp is in frenchso some ligns may not be in english
- March 26, 2019 at 5:27 pm #54626
JulienCKJM
ParticipantSo… What do all that mean? (You can also relate to the logs provided here since it seems to be the same issue. https://wclovers.com/forums/topic/manual-ordering-with-multiple-item-and-error-to-load-ajax-vendor-table/
But anyway, if you find the explanation or better, a way to fix it, just let me know please. Thank you! - March 28, 2019 at 9:55 am #54913
Uncaught Exception: Hybridauth requires the use of ‘session_start()’ at the start of your script, which appears to be disabled.
– Do you have disabled PHP session ?
- March 28, 2019 at 10:54 am #54923
JulienCKJM
ParticipantI haven’t knowingly disabled anything related to PHP session, but you can guide me on how to enable it if necessary please
- March 28, 2019 at 2:12 pm #55002
MemberCan you please talk to your hosting once regarding this!
- March 28, 2019 at 3:43 pm #55030
JulienCKJM
ParticipantHey they’ve helped me, and the problem was all about the memory allocated to the plugin (woocommerce for instance, I guess) was exhausted. Here is the message that helped to figure it out (and sorry for not exhibit it in the log fatal errors in woocommerce statut that you asked me, I thought it was irrelevent but turned out to be the key:). Here is the fatal error:
2019-03-28T15:26:58+00:00 CRITICAL Allowed memory size of 268435456 bytes exhausted (tried to allocate 4194312 bytes) dans /home/emeaon3u/public_html/wp-includes/wp-db.php à la ligne 2610
So in the end, they just allocated more memory (arround 512Mb or something like that) and everything is fine! Thank you again!! - March 28, 2019 at 5:08 pm #55038
MemberThat’s great, thanks for the update 🙂
- The topic ‘Ajax error’ is closed to new replies.
