Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Groups & Staffs › capability in Groups setting and capability setting is frozen
- This topic has 14 replies, 3 voices, and was last updated 6 years, 11 months ago by
- July 12, 2019 at 5:28 am #72122
rasalarhyme30
ParticipantHi, my capability setting is frozen everywhere I cannot use it and in review your plan on vendor registration no feature appear
- July 12, 2019 at 10:41 am #72137
Cap Luis
Participant - July 12, 2019 at 10:49 am #72138
Cap Luis
ParticipantDo you use WP FASTEST CACHE?
- July 13, 2019 at 11:38 pm #72380
rasalarhyme30
ParticipantYes sure
- July 14, 2019 at 5:14 am #72408
I don’t think this is because of caching.
- July 14, 2019 at 6:06 am #72417
rasalarhyme30
No there is not error generate - July 15, 2019 at 1:46 pm #72558
Cap Luis
ParticipantI have no errors in the log.
Fortunately mine got to work! I’m checking if it was Dokan’s fault! - July 15, 2019 at 2:15 pm #72566
Cap Luis
ParticipantI found the problem! developers can look with their own eyes!
Use DOKAN! dokan is breaking the Limits page, groups and staffs.
If you disable the Dokan plugin everything works normally!
- July 16, 2019 at 2:42 pm #72662
Umm … you may keep enable Dokan, but just disable it’s “Subscription” module and check.
- July 16, 2019 at 6:28 pm #72702
Cap Luis
ParticipantModule subscription on the Dokan Dashboard?
I deactivated and the problem continues!
- July 17, 2019 at 5:03 am #72736
MemberPlease check at wp-admin -> WooCommerce -> Status -> Logs -> fatal_erros log -> what errors are generating now?
- July 17, 2019 at 12:04 pm #72819
Cap Luis
ParticipantThere is no logging error, I just gave up, I’m wasting time on this.
But you said to disable the module of signatures in dokan, but the free version of dokan has no option of signatures, in this case it is not something limited to premium version, both dokan versions lock the limits settings.
Did you test it with your own eyes? it does not make sense to bump into my installation, I created a clean install to find the bug, and you could do the same. To help their customers.
Could you tell me if you tested dokan in conjunction with wcfm groups? I think you’d have the same mistake
I’ve already shown “how to cause the bug” yourself can try to cause this error.
install all WCFM add-ons, Dokan. go to config limits, and see your panel lock.
- July 18, 2019 at 12:14 pm #72946
Are you still using Dokan? Or, migrate to WCFM Marketplace!
As I remember, you have mentioned something like this some other thread.
If so, then we can discard this discussion!Thank You
- July 23, 2019 at 4:40 pm #73587
Cap Luis
ParticipantAfter the update I tried to use Dokan again, and the error continues, the page is broken and I can’t change any settings.
- July 25, 2019 at 1:16 pm #73871
– What error? Are you getting in log file!
Last time you told me, there is no error in log!
- The topic ‘capability in Groups setting and capability setting is frozen’ is closed to new replies.
