Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › capabillity tab bug + custom field product problem
- This topic has 22 replies, 3 voices, and was last updated 6 years, 1 month ago by
- June 17, 2019 at 10:19 am #68049
support12
I have 2 problems :
– When I click on the “capability” tab from the WCFM menu, my page refreshes. BUT the page remains frozen, impossible to do anything or scroller. I have to go back to the previous page. I can not use this tab.
– I use the plugin “Woo Set Price Note” to add behind the price of the product cleanly and clearly the unit of measure (example: kg, gr, piece …). However, from the WCFM interface, when I add a product, my field is not displayed. May it be necessary to use your “personalized product field”? In this case, how should you set it?Thank you so much.
- June 18, 2019 at 2:07 pm #68371
What is your WCFM Ultimate version?
Please be sure it’s at version 6.1.5
- June 18, 2019 at 2:24 pm #68373
- June 21, 2019 at 2:23 pm #68881
- July 1, 2019 at 2:13 pm #70561
support12
ParticipantHello, I do not have a fatal error in my logs
- July 4, 2019 at 5:24 am #70936
Please update WCFM and WCFM ultimate to the latest version, 6.2.2
- July 4, 2019 at 7:00 am #70971
support12
I made the update and I still have the same problem. It becomes urgent to solve it because I can not do any settings.
- July 4, 2019 at 7:01 am #70972
support12
ParticipantAs soon as I click on this tab, Chrome crashes and does not respond anymore !!!
- July 5, 2019 at 5:51 am #71130
And also show me this screenshot for updated plugins – https://wclovers.com/wp-content/uploads/2019/06/Capture-d%E2%80%99e%CC%81cran-2019-06-18-a%CC%80-16.24.12.png
- July 5, 2019 at 7:31 am #71151
support12
Here is the only mistake I have that dates from June 21, 2019 : 2019-06-17T09:57:55+00:00 CRITICAL Cannot declare class WC_Settings_Products, because the name is already in use dans /var/www/vhosts/com2ville.fr/portaildescommerces.com2ville.fr/wpcontent/plugins/woocommerce/includes/admin/settings/class-wc-settings-products.php à la ligne 0
You will find enclosed the proof of the update of the WCFM plugins.
You must be logged in to view attached files. - July 6, 2019 at 8:50 am #71280
Well, all WCFM plugins are at latest version.
Are you getting any error right now?
– It’s quite old error, for 21st June.
- July 17, 2019 at 8:02 am #72773
support12
I have no fatal error! it’s been more than a month since the problem is persistent despite the updates and I can not set the site.
- July 17, 2019 at 12:20 pm #72826
Cap Luis
ParticipantYou problem is Dokan! they already know this, they just need to fix
I’m so sure of this mistake! I’m betting you use DOKAN
- July 17, 2019 at 12:23 pm #72828
support12
ParticipantI do not use Dokan! And I have this problem for over a month ….. No log errors! It is hopeless
- July 17, 2019 at 7:58 pm #72880
Cap Luis
ParticipantSeriously?
- July 17, 2019 at 8:11 pm #72887
Cap Luis
ParticipantHere the problem stopped when I disabled the Dokan
- July 18, 2019 at 7:37 am #72922
support12
ParticipantI don’t use DOKAN ! ! !
- July 19, 2019 at 10:49 am #73055
Please update WCFM (6.2.4) and WCFM – Group (3.3.1) to the latest version.
Hope this will resolve for you!
This issue was coming due to PHP version, we have resolved this in latest update.
- July 19, 2019 at 11:47 am #73075
- July 19, 2019 at 11:49 am #73077
support12
ParticipantI don’t use WCFM – Group !
Here is a screenshot of the apage that does not work. It is very long has loaded and breaks Google Chrome! Impossible to work.
If you support him, I can give you access to the back-end so that you can see for yourself the problem.Attachments:
You must be logged in to view attached files. - July 19, 2019 at 1:38 pm #73093
- July 19, 2019 at 1:45 pm #73095
support12
ParticipantUne erreur de type E_ERROR a été causée dans la ligne 970 du fichier /var/www/vhosts/com2ville.fr/portaildescommerces.com2ville.fr/wp-content/plugins/wc-multivendor-marketplace/core/class-wcfmmp-store.php. Message d’erreur : Uncaught Error: Call to a member function show_star_rating() on null in /var/www/vhosts/com2ville.fr/portaildescommerces.com2ville.fr/wp-content/plugins/wc-multivendor-marketplace/core/class-wcfmmp-store.php:970
Stack trace:
#0 /var/www/vhosts/com2ville.fr/portaildescommerces.com2ville.fr/wp-content/plugins/wc-multivendor-marketplace/views/store-lists/wcfmmp-view-store-lists-card.php(74): WCFMmp_Store->show_star_rating()
#1 /var/www/vhosts/com2ville.fr/portaildescommerces.com2ville.fr/wp-content/plugins/wc-multivendor-marketplace/core/class-wcfmmp-template.php(38): include(‘/var/www/vhosts…’)
#2 /var/www/vhosts/com2ville.fr/portaildescommerces.com2ville.fr/wp-content/plugins/wc-multivendor-marketplace/views/store-lists/wcfmmp-view-store-lists-loop.php(54): WCFMmp_Template->get_template(‘store-lists/wcf…’, Array)
#3 /var/www/vhosts/com2ville.fr/portaildescommerces.com2ville.fr/wp-content/plugins/wc-multivendor-marketplace/core/class-wcfmmp-template.php(38): include(‘/var/www/vhosts…’)
#4 /var/www/vhosts/ - July 21, 2019 at 9:10 am #73265
Please update WCFM Marketplace to 3.1.5 and this will resolve for you.
